what paint gives a gloss finish on an engine
Ben
Gloss.
Enamel? Not sure on spelling.
Ben
Pretty sure enamel is what people use on the block/head etc. So yes it'll stand the heat
Ben
Really? I didn't think 2k would be that good at withstanding heat.
14000+ post superhero
check the small print on the back of cans, they tell you the limits of heat they will withstand. im sure normal car spraypaint has quite a high temperature threshold once dried .
i did my cosworth rocker cover in normal spray paint, lasted 2 years no problem.
All mine is done in 2k, block was cleaned fully then cure rust applied etched primed, primed then painted, seems ok so far, been painted about 4 years..
i did use on my engines ALIPHATIC-URETHANE
olso you need a special primer to.
gloss finish take the heat work werry well check my block.
thanks ferenc
JoeyBoyden
04-01-2024 02:36 PM
Wilsfoci
15
30-03-2016 10:26 PM
muz
16-08-2015 12:57 PM
