how to get more power without lag?
#121
The main reason i kept the 4wd manifold was so I could keep the standard heatshield , but also it helps resopnce at the cost of a little at the top end but you can still see 500 bhp on the 4wd manifold.
I found that I had less lag on the GT30 than on the T34.63 that was on the car but i also changed the exhaust cam and inlet cam timing at the same time. That and good mapping and setting up between Sitech and MSD.
#123
Testing the future
So what is the story with 4x4 gearboxes then I've been lead to believe that there too soft and can't handle power but when I got a red saph last year tht had done 280k mile with a 500 touring car spec engine it still had a standard 4x4 box n diffs in it, so when I called up graham Goode to talk about the car I queried that and he says has had standard box all it's days and was strong enough for 480bhp?
#124
I thought the exact same thing, some people here really do live in a fantasy
#126
20mins on track and it would be in 1000 pieces.
deathrider666
28-09-2015 06:12 PM
