Electrics question Re: Stereo wiring
Old 22-02-2005, 09:28 AM
Clare
Clare's Avatar
Default Electrics question Re: Stereo wiring
Forgive me if I come across a bit blonde, but electrics of any kind scare the crap out of me.
If I disconnect the battery in the Fiesta am I safe to cut the wiring to the Stereo/CD player thats in there?
The stereo has been wired into one of those white blokes that looks like lego so should be fairly straight forward.
Oh and once ive got all the old wiring out, is it pretty easy to re-wire back into a standard Ford block plug?
Old 22-02-2005, 09:32 AM
DaveEscos
DaveEscos's Avatar
yes
Old 22-02-2005, 09:36 AM
Daveyboy
Daveyboy's Avatar
you got a free white bloke with ya car too? bargain lol
Old 22-02-2005, 11:04 AM
KEVFRST
KEVFRST's Avatar
Make sure u solder all the joints or if u must, use the RED size bullet connectors.
Stritctly no Scotch locks
Old 22-02-2005, 11:18 AM
Oranoco
Oranoco's Avatar
Solder and heat shrink is the best way of doing this. I would offer to sort it for you but I'm nowhere near you down here.
Old 22-02-2005, 12:38 PM
Clare
Clare's Avatar
Daveyboy - trust you to pick up on that! lol
Solder......... hmmmm that sounds a bit dangerous for me to be doing (I am the person who sliced my finger open on a stanley knife ).
Cant I just cut the wires before the existing plug, strip the plastic back and re-thread it into a Ford block?
Old 22-02-2005, 12:39 PM
Daveyboy
Daveyboy's Avatar
yes you can
Old 22-02-2005, 12:42 PM
Clare
Clare's Avatar
Coolio, that's what I need to do then
Old 22-02-2005, 12:55 PM
Project ST
Project ST's Avatar
Go to Maplins and buy yourself a cheap crimping set if you really don't want to learn soldering
Old 22-02-2005, 01:23 PM
Clare
Clare's Avatar
Ive got a set of wire crimpers, but I dont see why I would need to crimp or solder if im wiring into a Ford block?
Old 22-02-2005, 01:33 PM
Jim Galbally
Jim Galbally's Avatar
clare, does the car still have the std connectors?
i'm assuming yes?
im also assuming that the stereo has an iso connector on it but the 2 plugs that connect to the std loom have been cut?
the BEST way to do it imho is to get yourself a new ISO connector (easily available from anywhere that sells stereos) and get a Ford-> ISO convertor loom (Ł10 from halfrauds)
that way theres zero cutting and you can always put the std stuff back in if necessary.
If the std connectors are cut anyway, you may aswell just solder the iso connector straight onto the original loom.
This is fairly straightforward, youll have 2-8 speaker wires, 2 power, an earth and a blue that will be piss easy to work out which is which...
make sure you get the yellow/red (power) wires round the right way tho, you want +12v going to yellow and ignition live going to red... get em the wrong way round and youll lose your presets all the time.
Old 22-02-2005, 01:46 PM
Clare
Clare's Avatar
Ok Jim, you have successfully confused me now. I thought this was going to be a really simple 30 minute job that I can do myself.
The standard Ford plugs have been cut out of the car and in their place are two white blocks that have wires screwed into them (I forget what these blocks are called). There is already a dodgy connection somewhere in there as I can hear the stereo interfering with a relay in the passenger footwell everytime it decides to have a hissy fit. Hence the reason I want to take it all out.
I want to put my own Sony stereo in there which is still on its original plugs and has a Sony - Ford connector........... hence the reason I want Ford connector blocks in the car instead of cack DIY ones.
Does that make sense?
Old 22-02-2005, 01:51 PM
Jim Galbally
yes that makes sense
unfortunately you're in the "worse case scenario" there
your best bet is to chop the plugs off the end of the sony stereo and solder them straight on to the car loom.
Old 22-02-2005, 01:54 PM
Clare
Clare's Avatar
Hmmmmm but that means I gotta get someone to help me and I had hoped to try and do it myself, plus I quite like my Sony having its own plugs, makes putting it in different cars really easy and makes me look clever
Daveyboy
Daveyboy's Avatar
Clare, if you want to leave it till the weekend, and you're still coming over, then im sure either Waps or myself can hook it up for you if you want?
Old 22-02-2005, 02:39 PM
Clare
Clare's Avatar
That is a very kind offer, thanks Dave............ just got to get the car started now tho cos its killed the battery
Old 22-02-2005, 02:45 PM
The Rapid 1
The Rapid 1's Avatar
Clare bye the sounds of it, recon your best bet is to chop the plug off the sony to ford connector (Ford plug to be removed) and connect these wires direct to the wiring comming from the car.
Agreed soldering is better but nothing wrong with through crimping IF using a decent set of crimpers, ie ratchet ones not the thin flimsy Ł2.50 set from Woolworths
Tis a ten minute job.
Do you know Steve Scotts place, how far from u is that cause im about 2-5 mins from there if want to pop down
Steve
Old 22-02-2005, 02:46 PM
Jim Galbally
clare, the other option is to buy a Ł10 convertor and solder this into the existing loom, which imho is pointless or get yourself some std plugs AND a convertor and solder this in... again, more pointless
you'd be ok as long if the std loom hadn't been cut :P
Old 22-02-2005, 02:51 PM
The Rapid 1
Actually Jim its not totally pointless cause if Clare was to by the a something to Ford converter she could chop one end off and wire this to her loom leaving a standard Ford plug on the loom as it should be, then whenever in future she changes her radio she knows she has just got to buy a ford to whatever make radio adaptor
Steve
Old 22-02-2005, 02:52 PM
Clare
Clare's Avatar
Jim - I see your point
Steve - A kind offer again, but as I said to Dave above, the car is dead at the mo and im about 40 mins away from Scottys. I'll go out and take the battery off it tonight and put it on charge so if necessary I can drive it somewhere near the end of the week.
Really hoped I could try and do it myself, hate coming across as a dumb blonde who hasn't got a clue
Old 22-02-2005, 02:53 PM
Clare
Clare's Avatar
Steve
This was the idea behind it all in the first place - im confused
Old 22-02-2005, 02:55 PM
Jim Galbally
agree with steve, nout wrong with crimping if done properly... however soldering is just as easy
Old 22-02-2005, 02:56 PM
The Rapid 1
Not at all
But depending what route u go down do you know what all the wires do, as jim said u will probably have 8 for the speakers 2x lives (and these dont just loose memories of radio if connected wrongly, the radio draws a different current load through each one so can at best blow fuses at worst read my adit at bottom ) an earth and if amps a remote switch lead and an aerial lead (not the same) also maybe light dimming wires etc so is a few wires to know
Many blokes (blonde or not ) would be happy to pay to have it done for them
Steve
Edited to say a small cost or drive is well worth it compared to the price of a fire
Old 22-02-2005, 02:59 PM
The Rapid 1
when u can mate or make even worse probs with dry joints
Steve
Old 22-02-2005, 03:01 PM
Jim Galbally
actually, it'll leave her with the wrong gender connector on the end which won't plug into anything
to be fair, any aftermarket stereo you buy will have an ISO connector on it anyway, so might aswell just solder that straight on... lol
Old 22-02-2005, 03:02 PM
The Rapid 1
Your best bet is that option if u dont mind spending the Ł20-30 for the adaptor, because as you say your radio is already fitted with a Sony to ford adaptor, so why not get the car back to how it should be with a Ford plug at the end of your Ford wiring, makes things far easier in the future
Steve
Jim Galbally
i can't beleive how complicated we're making a simple thing like stereo wiring sound even i'm confused
Old 22-02-2005, 03:04 PM
The Rapid 1
True
But sure u can buy a standard Ford connector surely if not as she passed Steves sure hed have one on a loom that he would let her have
Steve
Old 22-02-2005, 03:07 PM
Jim Galbally
agreed... but i think it'd be a pointless excescise which would waste time and money. the ONLY advantage of doing that would be that you could put a standard old 1980s for radio in the car with no hassle... but what are the chances of anyone ever wanting to put a POS like that back in the car, when you can get a half decent stereo from argos for Ł15quid (similar price to the adapter loom!)
Old 22-02-2005, 03:15 PM
The Rapid 1
Fair point mate
Its gone on so far now ive forhotten what coneectors and wires Clare actually got now
But somewhere it just a case of connecting via crimp/solder (not being nasty Clare but prob not your best option if u want to do it yourself ) the wires that are in the TERMINAL BLOCK
That way Clare could quite easily do it herself one wire at a time, only prob with that is means you are rellying on who ever wired it originally wiring to be correct and dont forget they used a terminal block (only jesting if the radio been working ok u should be alright, just have better connections )
If u do do it Clare u only need to remove the negative (-) from the battery, but also bear in mind that u must know any codes for the radio b4 doing this, or u will get more probs with trying to find out the code.
Steve
DaveEscos
DaveEscos's Avatar
christ its only a stereo
Perm live 1 cable (yellow)
ign live 1 cable (red)
Earth 1 cable (black)
speakers 2 cables for each speaker (+ve and -ve)
Old 22-02-2005, 03:21 PM
The Rapid 1
+ remote amp
+ aerial
+ lights dim
+ phone mute etc
But doubt somehow Clare is using these
Like said above is pretty simple wire for wire swap hopefully
Just a bit curious to the quality of Clares crimpers (not the vidal Sasson type that u plug in are they soz couldnt resist)
Steve
Old 22-02-2005, 04:37 PM
Clare
Clare's Avatar
Rahhhhhhhhhhhhhhhhhhhhh
I only wanna play music in my car without killing the battery
I have just about followed what Steve and Jim have written above (and thank you guys that is much appreciated). But I think what is now very apparent to me is that by doing this myself, I am relying on how the previous person has wired it up to re-wire my own, and I KNOW that it is currently wired up wrong.
Soooooo looks like im gonna have to hand it over to someone who knows a bit more about electrics than me and do the whole damsel in distress thing
I'll get the battery charged up so I can move the damn thing then sort it at the weekend.
Cheers guys for all the help
Old 22-02-2005, 04:49 PM
Spiky
Spiky's Avatar
if YOU are a dumb blonde click here, if not, dismiss
Old 22-02-2005, 04:59 PM
Clare
Clare's Avatar
Ha bloody ha, very amusing
The 3rd one listed @ Willowbridge is Graham, who is the only auto-elecy I trust in MK anyway
Old 22-02-2005, 05:35 PM
The Rapid 1
Your welcome
Not necesarily wrong just NOT WELL
Like I said if all appears to be fine just occasionaly cutting out crackling etc probably just a bad connection which u will sort out by using a better joining method, just do one wire at a time and should be ok, if u really not happy about doing it yourself and wanna pop over at weekend let me know
Steve
Music & Car Audio Chat
03-09-2017 01:24 PM
S3an
26-09-2015 11:39 PM
Kam B
24-09-2015 10:40 AM
S3an
13
13-09-2015 10:01 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: Electrics question Re: Stereo wiring
