Honda k20 experts
Old 15-12-2011 | 08:29 PM
749steve's Avatar
749steve
Default Honda k20 experts
I've decided I'm keeping my civic for a while.
So I want to know what tuning mods work?
And which ones are forum hype only?
For example do I need to go for k pro or just get the guy that does all the mapping at FST do it for me?
Old 15-12-2011 | 09:03 PM
big hyndy's Avatar
big hyndy
Try JDMY0.net Buddy!
This is the Forum Im on and they dont beat about the bush
Old 15-12-2011 | 09:11 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Boost - works
bolt on shite - doesn't work
Old 15-12-2011 | 09:21 PM
rs-tuner's Avatar
rs-tuner
Boost - works
Like it.
Old 15-12-2011 | 09:40 PM
749steve's Avatar
749steve
Boost - works
Boost doesn't work as I don't have a turbo!
And I don't want one
Old 15-12-2011 | 09:55 PM
RickyLee53's Avatar
RickyLee53
Kpro is your best bet, there 24 fuel maps and 24 timing maps alone on the K20! (tbh though this is overkill)
Sadly the above is the only way to go fast. Yes, you can get upto 50hp more out of the stock engine for around £2000-2500, but for £5000 you can get 200hp gain, with much better torque, spread of power and fuel economy.
250hp would keep you happy for about a week.
Old 15-12-2011 | 10:28 PM
vroooom ptssssh
It Wasnt Me!
Then enjoy small gains in horsepower vs big wad's of money to see such gains
P.s. Superchargers also make boost - jus sayin
Old 15-12-2011 | 10:40 PM
weegaz22's Avatar
weegaz22
dont bother...if your only keeping it for "a while" save the cash and spunk it on a faster motor later on
Old 15-12-2011 | 10:41 PM
749steve's Avatar
749steve
I don't want massive power, just to free up a few extra horses
Am I better fitting a LSD or tuning?
Old 15-12-2011 | 10:44 PM
749steve's Avatar
749steve
I've had faster motors in the past (320bhp saph was one of them) but I wanted a bit of reliability which is why I bought a Honda.
Old 15-12-2011 | 10:52 PM
danneth's Avatar
danneth
TORQUE!
LSD is pointless for standard power imo, either turbo/charge it, or just give it abit more noise
Old 15-12-2011 | 11:28 PM
749steve's Avatar
749steve
I've currently got a japspeed shorty manifold, standard cat(to keep it legal),piper 2.5" bore cat back system. And a modified/drilled airbox with a cone filter fitted inside.
Do RBC manifolds really make a differance?
Is the kpro the best option or would a custom map be better
Old 16-12-2011 | 03:40 AM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
get some throttle bodies on there a fella round my way has a type r running these it sounds bloody insane
Old 16-12-2011 | 08:17 AM
Paul1982sco's Avatar
Paul1982sco
For decent power increase you need to spend big.
For fast road spend your money on a good suspension set up and updated brakes.
For track use same as fast road but add 4 pots, decat, LSD, oil cooler and a baffled sump.
Old 16-12-2011 | 09:00 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Throttle bodies on a K20 sound absolutely epic, but the gains are small.
Old 16-12-2011 | 11:20 AM
749steve's Avatar
749steve
All ready have, I have HSD coilovers with adjustable arms and it's been set up fast road geometry
I also have brembo 4 pots with 325mm drilled and grooved discs
Here is a link to the thread on my car
https://passionford.com/forum/restor...ic-type-r.html
Old 16-12-2011 | 01:31 PM
Paul1982sco
Nice spec so far. Without going into daft money a induction kit like a Gruppe M of J's Racing style, LSD, oil cooler,baffled sump would make it a really good all rounder. Without going forced induction your looking at cams or NOS but again crazy money for very little gain.
Mate has a 310bhp Cosmic Grey 1 with a Jackson Charger, K-Pro, IPS cams, Tokco suspension, DC and Progress braces, 4pot brakes with custom bells and discs, Quafie LSD, J's induction kit and exhaust manifold, custom 3inch manifold back exhaust.
Old 16-12-2011 | 03:42 PM
rsmark86's Avatar
rsmark86
Your problem mate is the k20 is highly tuned from the factory, so you will need to spend quite a bit to get anything
I would spend 3k and have a supercharger conversion
Or throttle bodies, cams, and decat, just keep your old cat for mot to swap over
Good luck what ever you decide
A mate of mine had a 350bhp turbo one and easily sat with my mate 430bhp mk2 frs
Old 16-12-2011 | 04:03 PM
749steve's Avatar
749steve
a induction kit like a Gruppe M of J's Racing style.
I wouldn't get any extra air flow than what I've already got with my two cold air feeds and my cone filter in the airbox. And im not into cutting my scuttle panel and bolting a scoop on it
I had mentioned LSD earlier in this thread as I thought getting the power down better will make it nicer/faster on the road. But someone said not too bother
But I don't want to spend silly money as I've already spent over 2k on the car since I bought it
Old 16-12-2011 | 04:58 PM
mark r's Avatar
mark r
friend has a quaife diff on his along with a toda exhaust and inlet manifold, cpl racing honda data ecu stop tech brakes running approx 250bhp.goes realy well both on rd and track
Old 16-12-2011 | 05:03 PM
Paul1982sco
Trust me it makes a whole lot of difference with the LSD. Not a fan of the Gruppe M either that's why I prefer the J's as its fed from the front grill, for cheap power NOS is your best bet.
Old 16-12-2011 | 06:08 PM
RS Grant's Avatar
RS Grant
Made in Scotland
I'd drop in a fruity MFactory final drive if you're not planning to boost the engine at any point... no point being geared for 160-170mph (at a guess?) unless you can get there without holding it on WOT for long periods. I'd gladly sacrifice a willy waving top speed to gain more useful improvements through the gears.
While the box was out, I'd also drop in an LSD and uprate the clutch/flywheel.
Cheers,
Grant
Old 16-12-2011 | 06:44 PM
weegaz22's Avatar
weegaz22
what rubber have you got on it?
Old 16-12-2011 | 10:08 PM
749steve's Avatar
749steve
Toyo proxy t1r's
Old 16-12-2011 | 10:52 PM
RickyLee53's Avatar
RickyLee53
Cheers,
Grant
The gears are pretty close anyway, you gain 20mph per gear which is about right IMO. Any closer I reckon you'd lose time on the shifts.
If you don't want to go turbo i'd save the money and put it towards a new car. Spending 500-£2000 on mods won't make a lot of difference at all.
Old 17-12-2011 | 10:16 AM
Fullflush's Avatar
Fullflush
These engines are only vaugely good if you ram a load of boost down then.
A.t.p
29-09-2015 05:04 PM
DavidK
27-09-2015 02:55 PM
Mark Mawson
31-08-2015 07:09 PM
Quick Reply: Honda k20 experts
