Car running sh*t when warm!!
Old 09-12-2011 | 04:25 PM
Fordmad!'s Avatar
Fordmad!
Default Car running sh*t when warm!!
This is now driving me mad!
Car would struggle to run at all! Changed ECU and run perfect!
Take the car out for 5 minutes and soon as its warm plays up! Dosnt always do it but does it now and then!
Any ideas, changed most of the sensors, pipes, etc. Could it be cheap plugs breaking down when hot?
Any suggestions would be helpfull as right now all i want to do is set fire to it!
Old 09-12-2011 | 04:31 PM
LHD220Turbo's Avatar
LHD220Turbo
what car?
Old 09-12-2011 | 04:37 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by LHD220Turbo
what car?
That would help lol
Steve
Old 09-12-2011 | 04:40 PM
Fordmad!'s Avatar
Fordmad!
Lol sorry its an xr3i efi. Must of had 10 posts about it already but no luck yet!
Old 09-12-2011 | 04:41 PM
kev 3dr's Avatar
kev 3dr
wrong ecu or map ??
Old 09-12-2011 | 04:48 PM
Fordmad!'s Avatar
Fordmad!
ECU numbers are the same on both and it seemed to run fine when i changed them!
I do have a spare map sensor but wouldnt it do it from cold if it that was the problem?
Old 09-12-2011 | 07:30 PM
Fordmad!'s Avatar
Fordmad!
Any help lads would be good. Even if its just somthing i can try!
Seriously stressing me out Lol
Old 09-12-2011 | 07:33 PM
matts1's Avatar
matts1
Stab in the dark but do these have a cold start valve? could it be sticking meaning extra fuel is being dumped in and overfuelling, when not needed as the engine warms up and should have cut back??
Old 09-12-2011 | 07:39 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
is the irv on the inlet or on the air box?
it was designed as on the airbox but recalled to put it on the inlet
is it puffing out black sooty smoke when its playing up?
with efi i generally un plug one thing at a time, it will run fine with most things disconnected
Old 09-12-2011 | 07:58 PM
Fordmad!'s Avatar
Fordmad!
The cold start valve is the one in the thermostat i think. I have changed it for a second hand one but am thinking of buying one new as most people say thats the problem.
Nothing on the airbox so must be on the inlet although im not sure where.
Im not sure about the smoke as when it plays up im usually in the road with traffic behind which is pretty embarresing lol
It was overfuelling before i changed the ecu but since ive changed it, it dosnt smell of fuel anymore and did/does run alot better.
I have new but cheap plugs in which i think could be causing the problem? Have spent enough already trying to solve the problem when i can just get another engine cheap enough!
Old 09-12-2011 | 08:39 PM
xr4x4rs's Avatar
xr4x4rs
change the water temp sensor for ecu, think its at the back of the inlet manifold somewhere
or in a water pipe at the back
Old 09-12-2011 | 09:20 PM
Fordmad!'s Avatar
Fordmad!
Theres a sensor at the back of the manifold in the middle a blacl plug i think? That sthe only one i havnt tried! Will try that next!
Old 09-12-2011 | 09:47 PM
I was gonna say water temp sensor cause i had the same fault on my cossie.If i was doing about 60/70 mph it would be ok but as soon as i got into town traffic and the engine got warm it used to run/misfire badly.
Old 10-12-2011 | 07:41 AM
Fordmad!'s Avatar
Fordmad!
Would it also be called the engine coolant temperature sensor ECT?
It out of view right at the back of the inlet
Old 10-12-2011 | 01:42 PM
xr4x4rs's Avatar
xr4x4rs
yes
its not the one at the front of the head this is just the temp gauge sensor, the ecu one should be at the back somewhere , but i carnt remember if the efi 3i has one as its been so long since i had mine
Old 10-12-2011 | 09:11 PM
Hobomassiv's Avatar
Hobomassiv
Can you be a bit more specific?
My Ka is having asimilar problem, It idles fine, i let it warm up a bit but then as soon as im driving it spits and pops and holds back then jsut eventually cuts out!
Old 10-12-2011 | 10:17 PM
studabear's Avatar
studabear
get it on a emissions machine, ega (exhaust gas analyser)
Post the readings
Old 10-12-2011 | 10:33 PM
weegaz22's Avatar
weegaz22
Bog standard engine? no FSE valves or other crap bolted to it?
Old 11-12-2011 | 05:09 PM
Fordmad!'s Avatar
Fordmad!
Well it hasnt happened again but will still get it to the garage on the machine i think!
Engine is bog standard!
The sensor im on about is out of view, bottom of the inlet above the oil fiter. Hard to get too, easier to just take inlet off i think.
Is the ega machine the one the use on the MOT as its going in Thursday for one then.
Old 11-12-2011 | 08:13 PM
I carnt really be more specific than that realy.It felt like the car was running on 3cylinders.and the car was just chugging.
Old 11-12-2011 | 08:17 PM
studabear's Avatar
studabear
yeah ega is the mot machine, the readings will give us more idea whats going on with the engine.
Old 11-12-2011 | 08:23 PM
Fordmad!'s Avatar
Fordmad!
Well i'll have to wait till thursday then. Even though the garage should be able to point me in the right direction if its faulty surly?
Adam-M
22
10-08-2015 11:46 AM
Zoggon
10-08-2015 11:39 AM
yawiejon
15
09-08-2015 07:36 PM
knight19770
04-08-2015 01:36 PM
BMROVAL
Shows & Track Days
31-07-2015 06:32 PM
