Boot mounted fuel cell, worth it??
Hello everyone
as above really, I am currently building a series 2 track car
My new engine has an external swirl pot, is it worth getting a fuel cell in the boot or will the standard tank be fine??
Also will it still be road legal with a fuel tank in the back?
cheers
cheers
I have just recently put a tank into the boot of my RS2k mk5 track car, have yet to get a fresh mot on it, but I think it needs to have a lockable fuel cap in order to pass, as long as the tank is properly secured and looks like it is fit for purpose also!
I went this route after I had a fuel pump failure on a track day, and what with the original fuel pump being internal, it was game over for me that day. But with the external fuel pump I would have had the option to swap them over, as long as I have a spare with me of course.
The fuel cell is mounted above the rear axle line, just ahead of the spare wheel well, and has raised the centre of gravity a bit I guess, as the original tank was mounted below the rear seats. But the ease of access to everything is a bonus.
Your new engine has an ext. swirl pot? You sure that is referring to a fuel swirl pot as really that has no connection the the motor.
If you OE tank is good i would keep it. It will be positioned far bar than having on incar in terms of COG plus the cost of running an decent internal setup will probably run you half a dozen track days(in terms of £££).
I would definatly run a lift,swirl and main setup though as OE tanks arent great for fuel surge when run low.
JK12
33
26-04-2021 12:09 PM
borboyous
22-08-2015 11:17 AM
