focus running problem
Old Nov 7, 2011 | 08:59 PM
  #41
COCHYN's Avatar
COCHYN
Ignition Run / ACC circuit failure
So as I recall, I disconnected my battery for a few hours and reconnected it and the code had erased. But I had a SnapOn diagnostics unit that I could get rid of DTC codes too just in case.
Old Nov 7, 2011 | 09:04 PM
  #42
Rsmat's Avatar
Rsmat
Top result guys... Hope it's the cure dicko pal.
Old Nov 7, 2011 | 09:05 PM
  #43
Dicko&Vacant's Avatar
Dicko&Vacant
What does the ignition run acc fail mean? Any idea.
Old Nov 7, 2011 | 09:13 PM
  #44
Dicko&Vacant
Lol i can't see it mat im ain't been that lucky with this focus lol
  #45
COCHYN's Avatar
COCHYN
Check your fuse box, can't recall which number (sorry, been a while since I played with a Focus RS). But you may have popped a fuse if you've done anything electrical, even hit an earth with a live etc.
Old Nov 7, 2011 | 09:15 PM
  #46
Rsmat's Avatar
Rsmat
Have faith mate..
Old Nov 7, 2011 | 09:20 PM
  #47
COCHYN's Avatar
COCHYN
Aaaaah just remembered something else, does your run a lambda or a dummy lambda? That code frequently came up with mine as it did tend to fry lambda's
Old Nov 7, 2011 | 09:23 PM
  #48
Dicko&Vacant
Yeah still runs the lambda in downpipe mate
Old Nov 7, 2011 | 09:26 PM
  #49
Dicko&Vacant
Yeah still runs the lambda in downpipe mate, i also whipped the plugs out earlier to have a look and 1 2 3 are all black with a nice white tip but number 4 is just pure black? Dunno if summet a miss there.
Old Nov 7, 2011 | 09:27 PM
  #50
COCHYN's Avatar
COCHYN
Borrow one off someone, but then again wouldn't give you the boost issue. No air leaks, specifically around the inlet side i.e. hair line splits which commonly occur?
As for the plugs, have you got a spare set to just pop in and give a go? Are they gapped correctly?
Old Nov 7, 2011 | 09:34 PM
  #51
Dicko&Vacant
Yeah i know it won't cause the boost issue but at least the car used to drive fine lol i mite just buy one from work tomorrow.
Old Nov 7, 2011 | 09:54 PM
  #52
COCHYN's Avatar
COCHYN
Would be worth it, but that fault code is electrical, so could be a small number of things. But change lambda if cheap enough, check the interior fuses and finally get over to Mark Shead and ask him to finish off what he started. If it was fine before he mapped it, then maybe something was missed? Easily done.
With these cars, they're normally the most reliable on the road from my experience and the problems that occur always give you a headache but turn out to be easy fixes. That is, unless the previous owners were donuts who treated the cars poorly.
Old Nov 7, 2011 | 10:43 PM
  #53
pcbp97's Avatar
pcbp97
thats ok mate ,i think you need to change the complete tank though.did you try filling up to see if the problem went
Old Nov 8, 2011 | 07:37 AM
  #54
COCHYN's Avatar
COCHYN
Not being funny, but that sounds like an old MK2 Escort pinto bodge job fix These newer cars, especially the Focus RS shouldn't be that tempremental, especially where boost is concerned. Its gotta be something along the lines of a sensor, injectors, plugs, regulator etc. More of a component as apposed to low fuel because unlike an alloy fuel race tank with just a foam insert and a 044 pump, the RS tank isn't a homemade type of thing
Old Nov 8, 2011 | 06:31 PM
  #55
Dicko&Vacant
Well new lambda fitted and yep still the same lol.
Old Nov 8, 2011 | 06:42 PM
  #56
COCHYN's Avatar
COCHYN
Was an unlikely option, but an option nonetheleast. You need to get into a garage mate, if you've gone through it with a fine tooth comb then that's the sensible option, go back and finish the map properly
Old Nov 8, 2011 | 06:46 PM
  #57
Dicko&Vacant
Gonna get my fuel system fitted then just take it somewhere and let them sort it lol before it gets broken
Old Nov 8, 2011 | 06:59 PM
  #58
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
really hope you get it sorted soon lee
Old Nov 9, 2011 | 11:20 AM
  #59
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
For what its worth - the code reading via the dash is of very little use at the best of times. The codes shown on there are rarely direct fault codes from the engine ECU. Most of them are from the GEM module/dash setup.Dicko - if you want to send some screenshots of the live data from the Autronic over to me i'll happily take a look at them and see if I can see anything out of the ordinary.It is possible that a sensor is playing up as has been mentioned. I'd quickly check the pipe connection to the MAP sensor too for what its worth!
Old Nov 9, 2011 | 12:41 PM
  #60
COCHYN's Avatar
COCHYN
I think we should arrange a pole and bet what the problem will be
I'm going for split vaccum hose somewhere on the inlet
Old Nov 21, 2011 | 06:46 PM
  #61
RSGARETHW's Avatar
RSGARETHW
always working
any joy dicko?
Old Nov 21, 2011 | 07:51 PM
  #62
Dicko&Vacant
See other thread mate pulled some faults off the errors screen on autronic.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
