focus running problem
Old Nov 6, 2011 | 11:37 AM
Dicko&Vacant's Avatar
Dicko&Vacant
Default focus running problem
Rite guys my focus has developed a running fault.
The car will tickover fine but when you try rev the car nothing happens at first it hesitates then will rev up,same when driving if you come off the throttle then back on nowt happens at first then it will splutter and pop and bang?? Its also quite bad when you corner or come round a round about then try to accelerate, its as if its running out of fuel so was wondering if my pump could be on its way out or anybody have any other ideas?
Old Nov 6, 2011 | 11:39 AM
RSGARETHW's Avatar
RSGARETHW
always working
fuel pressure reg?
Old Nov 6, 2011 | 01:37 PM
Dicko&Vacant
Originally Posted by RSGARETHW
fuel pressure reg?
Summet else to think about
Old Nov 6, 2011 | 03:00 PM
Gary F's Avatar
Gary F
And I get stick for my car? Fucking scrap it
Old Nov 6, 2011 | 03:02 PM
Gary F's Avatar
Gary F
I know I haven't got a Focus but I had similar problems and it turned out to be a fuel pump.
Old Nov 6, 2011 | 03:11 PM
Dicko&Vacant
Gary its close to coming to bits mate dont worry lol
Old Nov 6, 2011 | 06:03 PM
COCHYN's Avatar
COCHYN
Sounds like you've had a lot of problems since day one with this car mate
As said, check fuel pump and basics such as plugs etc.
Old Nov 6, 2011 | 06:48 PM
Dicko&Vacant
It was fine for a good 7mth or so then clutch went and its been downhill ever since lol will be an animal if i ever get it sorted lol
Old Nov 6, 2011 | 08:18 PM
Rsmat's Avatar
Rsmat
Pump or regulator.. Mate
Old Nov 6, 2011 | 08:40 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
check the fuel pressure, simples
if ok then lambda readings
Old Nov 6, 2011 | 08:45 PM
pcbp97's Avatar
pcbp97
does the car only do this below half a tank of fuel
Old Nov 6, 2011 | 09:27 PM
TimC's Avatar
TimC
Does the car still have a air flow sensor? My boggo 1.2 daily corsa had a similar running issue and it was the MAF.
Old Nov 7, 2011 | 08:35 AM
Dicko&Vacant
Well I've got a new regulator to go on anyway and also got a new fuel set up to fit in in boot so think ill also change in tank pump while its out.
Then need to find yet another tuner to try sort my boost issue lol
Old Nov 7, 2011 | 08:45 AM
Dicko&Vacant
At the moment yep but tbh i ain't filled it up to try???? What would it indicte if it was ok above half a tank.
Old Nov 7, 2011 | 08:48 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
what fuel pump is it???
Old Nov 7, 2011 | 10:32 AM
Dicko&Vacant
Im not 100% Matt i think its only a walbro mark shead fitted it last year when he mapped the car for previous owner.
Old Nov 7, 2011 | 11:02 AM
RSGARETHW's Avatar
RSGARETHW
always working
Why another tuner? Why can't you take it back to mark?
Old Nov 7, 2011 | 11:32 AM
Dicko&Vacant
Because I've already been to mark my self, it was mapped with a boost problem and just left no fault finding etc tried. So im not prepared to travel the distance again with fuel cost etc for the same to happen again.
Old Nov 7, 2011 | 11:39 AM
pcbp97's Avatar
pcbp97
hello mate ,the reason i asked was because my focus does the same below half a tank,apparently the swirl pot cracks giving the same symptoms .i still need to change mine but at the moment keeping above half a tank erradicates the issue.
HTH
Steve
Old Nov 7, 2011 | 12:06 PM
Dicko&Vacant
Ah rite thanks for that mate give me reason to fill it tonight. Can you just change the swirl pot or is it a new tank?
Old Nov 7, 2011 | 01:24 PM
COCHYN's Avatar
COCHYN
If it was mapped by Mark, how did it leave with an obvious boost problem? Wouldn't think or anyone else would be silly enough to leave the premises with a popping and spluttering car on boost.
As for it running below the fuel mark, I wouldn't think they're that black and white or tempremental. Mine ran well under the red several times
Old Nov 7, 2011 | 03:09 PM
Dicko&Vacant
No it never left marks popping etc that's only just started lol. The boost fault it left marks is it will hit 2bar of boost but when car reaches 5k revs boost drops dramatically.
Old Nov 7, 2011 | 03:59 PM
Gary F's Avatar
Gary F
Take it to MSD.... On second thoughts
Old Nov 7, 2011 | 04:06 PM
James @ M Developments.'s Avatar
Meaning?
Been here recently have you? or have you learnt to read a work report?
Old Nov 7, 2011 | 04:11 PM
Have you checked the chip connection? if it has one fitted
I had one in last week from a very well known tuner that still had laquer covering the chip connection causing all sorts of running issues!
Old Nov 7, 2011 | 04:25 PM
BRAM's Avatar
BRAM
Is your charging ok mate? i had something similar before on a friends car when the alternator wasn't charging causing popping and banging.
Or how about your tps, havent you changed your inlet and throttle body doe's your tps not need setting up.
Are you still on autronic management can you not plug it into a laptop and check for fault codes?
Just a few ideas mate i might be way off the mark but worth a try befor you break it ha ha
Old Nov 7, 2011 | 04:40 PM
Dicko&Vacant
Yeah still on autronic i wouldn't know where to start or look for codes on laptop lol id probs make it worse
Old Nov 7, 2011 | 04:48 PM
v man's Avatar
v man
Zee Germans are coming
id take it back to sheede to sort the boost problem first off
give rob a bell at scc
he is very good with these cars
Old Nov 7, 2011 | 05:06 PM
COCHYN's Avatar
COCHYN
Have you don't the basic fault test on the dash? Pressing the trip button as you turn the key, it brings up the list of DTC codes. Have a look at what code it is and I'll tell you what it means.
Old Nov 7, 2011 | 05:09 PM
Dicko&Vacant
Cochyn will it still do it even though im on different management?
Old Nov 7, 2011 | 05:10 PM
COCHYN's Avatar
COCHYN
Hmm....good question, never really thought to check on a car with different management. Check it out though, I'm on here for a bit
Old Nov 7, 2011 | 05:17 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
sounds like fuel surge to me mate, get that new fuel set up fitted and see what happens bud, not havin much luck lee... did you change your inlet?
Old Nov 7, 2011 | 06:14 PM
Rsmat's Avatar
Rsmat
No it won't mate... As your on different management.
Do you have a scanguage in the car..? Iirc tho im sure a scanguage won't work aswell with being different management.
Old Nov 7, 2011 | 06:28 PM
COCHYN's Avatar
COCHYN
Only one way to find out, get out there and check out the dash!
Old Nov 7, 2011 | 06:59 PM
Rsmat's Avatar
Rsmat
It reads off the ecu which in turn reads the sensors... So unless his sittings can send the same setting to the digital display If it reads then I can't see it working.
Old Nov 7, 2011 | 07:22 PM
Gary F's Avatar
Gary F
Originally Posted by James @ M Developments.
Meaning?
No, thanks!
Old Nov 7, 2011 | 07:36 PM
COCHYN's Avatar
COCHYN
Exactly! Who knows how its been fitted, so at least try it and then rule it out. Then onto the next bright idea
Old Nov 7, 2011 | 07:45 PM
Dicko&Vacant
Rite just been to check and it brings fookin loads of different things and numbers etc up?
Old Nov 7, 2011 | 08:39 PM
COCHYN's Avatar
COCHYN
Aaaaaaaanyway.....
Right pal, all those codes have a meaning, so don't worry. Right, so press the button and turn the key as you did and fire it up, the clocks will do a whole gauge sweep and then you let go of the trip button. Every time you press the button, you'll come across boost pressure, digital rev counter, battery volts etc. etc.
So what you do now is press the button and go through the list until you come across a dtc flashing with a number/code straight after it.
What number is it?
Old Nov 7, 2011 | 08:54 PM
Dicko&Vacant
Right the number that flashes with the dtc is 9359?
