300hp focus zetec
300hp focus zetec
So my car is due back next week after having a rather large amount of work done to take it up to an expected 300 hp figure. Problem is I won't be changing the clutch until the current one goes, probably not long but can't afford it right now and the standard clutch has done less than 10k miles.
The engine is 2.0 blacktop with mtx75 box. Just wondering what to do with clutch, flywheel and probably differential when I upgrade this area? Been told the ap racing rs upgrade clutch should fit and I plan on fitting quiffe diff. But do I need to change the flywheel, if so what would you recommend?
Any help much appreciated. Thanks, Ali.
TPM961
15-01-2018 10:50 AM
grishenko45
09-09-2015 12:58 PM
