Cossie 370bhp @ 14psi
full engine rebuild
new crank
steel conrods
arp2000 rod bolts
engine rebore
mahle oversized pistons
new total seal piston rings
heavy duty big end and main bearings
uprated oil pump
full fine tolerance engine balance
baffeled sump
mild ported and polished head
new lifters
new head bolts
heavy duty mls head gasket
full gasket kit
kevlar clutch kit
aet gt2871 ball bearing hybrid turbo with the smallest turbo housing to give maximum acceleration and no lag
haltec 2000 ecu
pro alloy intercooler
300whp @ 1.1 bar
dont no why you have gone to the extremes to put a thread up i will post graph tomoz perhaps ur running old shitty ford ecu mine was live mapped then put on hub packs not rolling road why do u think the haltec platinum range is 2000 quid to buy ?????
dont have a clue wot cams are but i know they was dialled in for perfect timing not just done to nearest tooth
new crank
steel conrods
arp2000 rod bolts
engine rebore
uprated oil pump
baffeled sump
new lifters
new head bolts
full gasket kit
kevlar clutch kit
haltec 2000 ecu
300whp @ 1.1 bar
2 liter cossie at high rpm low boost - why not?
From Garrett website:
http://www.turbobygarrett.com/turbob...R_743347_4.htm
GT2871 is very capable of 350+ hp.
More boost Igor!
full engine rebuild
new crank
steel conrods
arp2000 rod bolts
engine rebore
uprated oil pump
baffeled sump
new lifters
new head bolts
full gasket kit
kevlar clutch kit
haltec 2000 ecu
300whp @ 1.1 bar
new crank
steel conrods
arp2000 rod bolts
engine rebore
uprated oil pump
baffeled sump
new lifters
new head bolts
full gasket kit
kevlar clutch kit
haltec 2000 ecu
300whp @ 1.1 bar
What flavour injectors are on there...? As for the "old shitty ford ECU" comment, there's nothing stopping one running a much more powerful engine, after all, all it does is calculate when to inject fuel and fire a spark, and their "old shitty" 8 bit processors can do that in their sleep
Always find it funny how people assume that because something's old it's automatically incapable of doing something it was actually designed to do.
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Uncle Tony, you can build, or should i say have built some of the most famous YBs outhere and mapped trillions to perfection AND you're telling me you CAN'T work a coonting mobile phone??
My gast is flabbered...
Boost addict
tony im surprised you dont tell steve that fraser blew his car away at the dyno day in july on a t38 turbo
507bhp iirc ?
onto the question i dont think thats possible at all maybe if it was running another 10-15psi it might come close
Zee Germans are coming
look guys juts fix my phone and stop bickering ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
here it is copied and pasted here for you as I know you really want to help lol
help with mobile phone network connection Bought an htc touch pro2 used turned out to be locked, got an unlock code I can now access all the menu's but it won't connect to my air time provider
The sim I have is vodaphone and works fine in my other phone
What settings do I need to enter and where
googled loads can't find the answer to help lol
even though they look the same there not
should have got the i phone anyway
300whp @ 1.1 bar
Mine was live mapped by one of the best cossie tuners in the country thanks , he also set up my cams
Steve
