Power Steering Fluid into Engine Oil
Old 25-09-2011, 07:34 PM
est1984
est1984's Avatar
Default Power Steering Fluid into Engine Oil
Okay, so I've just realised I've put power steering fluid into the engine oil place.
I am absolutely shitting a brick as I am worried about how I am going to get to work tommorrow.
It's driving perfectly fine which I can't understand.
I've got a Ford garage which is right next to my work place, but its about 45 miles away from where I live.
Do you guys think its a bad idea to drive it for another 45 miles to work and get it drained by the ford garage guys?
What precautions am I supposed to take?
Old 25-09-2011, 07:36 PM
Jeffers_RST
Jeffers_RST's Avatar
Dont drive it! and call the day off work and do an oil change yourself!
Old 25-09-2011, 07:38 PM
est1984
est1984's Avatar
I've only just started my job, I'm in such a awkward position! Won't I need someone to blast something into the engine in order to clean it all out?
Old 25-09-2011, 07:40 PM
Jeffers_RST
yeah know what u mean but you shouldnt drive it! what car is it? is it worth risking damage to the engine?
could just do an engine flush, do an oil change twice or more...
Old 25-09-2011, 07:44 PM
est1984
est1984's Avatar
It's a Ford Focus 98, 1.8. Well its not worth risking the damage, your right. I rather not put it at further risk and cause me more problems later when I need to use the car.
Is the engine flush a long task?
When you say do an oil change twice, do you mean drain out whats in there put new oil into it, drive it around, and then drain and put more new oil in?
Old 25-09-2011, 08:11 PM
Jeffers_RST
Well it all depends on how much you've put in! But if youve put alot in, and it causes problems, then your gonna have yourself a much bigger headache. Still at least its an oil and not water lol
Yeah change oil, run it up for 5 mins and change it again. Should do it some good anyway.
Cheers ,Neil
Old 25-09-2011, 08:18 PM
bunnymofo
bunnymofo's Avatar
how much did you put in ? if its just a lil but i wouldnt worry. i once had to top mine up with gear oil and it was ok, wan it for 2k miles with it in.
Old 25-09-2011, 08:19 PM
Jeffers_RST
What i wanna know is how you put pas fluid in there in the first place!!
Old 25-09-2011, 08:27 PM
bunnymofo
bunnymofo's Avatar
Old 25-09-2011, 09:47 PM
martysmartie
martysmartie's Avatar
DON'T drive it as said, you may have already caused damage by doing so!
Either use public transport etc for work, or if you really need the car explain to work see if you can take a days holiday etc.
Regardless of the amount it will still need changing.
It's easy enough to do yourself, do a straight oil change (Without getting to running temperature like in the usual fasion) or do a flush as well.
Incidentally the fresh oil you will NEED is a decent quality 5W/30
Martin
Old 25-09-2011, 10:51 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
if its less than 2ltrs it`ll be fine.
pas fluid is thinner but its better than no oil.
if youve made the engine over filled it`ll be smokey and poss damage the cat, but chances are you wont do bugger all wrong.
oil change takes 5 mins with nothing but something to catch 5ltrs of oil and a 13mm spanner
Old 25-09-2011, 11:15 PM
est1984
est1984's Avatar
@jeffers
true, atleast it isn't water, but im sure i wouldnt have been daft enough to do that to be honest lol... saying that i was daft enough to put in the pas...
i only put in about a 0.25l in, there was a quater of a litre bottle left
i called a very cool rac chap down and he advised me to take to a rac approved garage for it to be changed and have it flushed, due to some of the advise you had given to me i think it would have been easier for someone who has done this before over a few times to do it rather than myself and having to check it over and over again before i was sure i had done it correct.
@bunnyi only put in 0.25l approximately... gear oil? im sure i haven't had the need to change gear oil before, but what happen after 2k? did the bearings go on it?
@jeffers, i only managed to put it in as the bottle looked exactly the same as the pas liquid and some smart soilder in my family moved the bottles around... but to be honest i should have checked tho really... i will ensure that this mistake never happens again in my life...
@martysmartie, your advise is along the same lines as everyone elses i appreciate your concern. I have text my manager today hopefully he can understand that the car has gone down. I just hope i've texted the correct number as i haven't had a delivery report (still crapping a brick lol) i love my new job and i never wanted to get into this situation so its abit of a bummer.
@cossie, it sure was less than 2ltrs
thanks guys you've taken a whole weight of my shoulders worrying about it... now i know its in a garage i just need to get on top of it tommorrow and ensure things go smoothly there.
Old 25-09-2011, 11:46 PM
bunnymofo
bunnymofo's Avatar
Originally Posted by est1984
@jeffers
i mean i put gear oil into engine oil once lol
same thing, bootle looked the same. ut i realised as i was going it and then put in some thin engine oil to thin it down a bit.
JoeyBoyden
20
22-08-2015 03:23 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Power Steering Fluid into Engine Oil
