Poor design...
Me and my mate were discussing earlier what is the worst bit of design in a car ever.
I was thinking along the lines of ford bolting a turbo onto the CVH
What do you think is the worst error in a cars design?
must be the front brake setup on a hyundai coupe, got to luv rice and rust, with the brake disc mounted on the back of the hub, type wheel bearing out jobie.
Almost everything saab is shait..
But lets not forget the front of a fiat multipla! epic fail..
if they didnt we would never have had rs turbos.
20 years ago it was ahead of its time
and still a capable engine today with people getting up to and over 300bhp using standard componats such as standard ford headgaskets, exhaust manifold, headbolts etc
so hardly a bad engine really
most problems are down to owners not mantaing them properly
some engines of similar size need alot more parts replacing to make similiar power even by today standards
how many 300bhp corsa vxrs do you see? and there engine are prone to failure and thats by todays standards
mk3 fiestas , not thinking of the idea that water gets trapped behind the petrol cap and the inner body panel , using a shitty foam gasket and not using some sort of decent sealant between the panels and on the sills to stop them rusting .
also transit connect pressed steel sump pan rotted through after only 8 months on a brand new van
and ford for not making a new decent 4x4 big powered rs to match the likes of the evos etc as theres still clearly a market for them , someone at ford must not have any business sense
cheers paul
cheers paul
Cam belts that drive water pumps.
Cavaliers spring to mind! Water pump fails and takes the engine with it!
Dash/heater bulbs that are always lit, so they eventually burn out. Then they make them a complete arse to change! Combo B van heater bulbs for instance, you have to virtually strip down the complete centre console to get at the tiny bulbs.
The biggest motoring fail for me has to be the prius, all those precious metals in the huge batteries that are shipped half way round the world to be produced, then half way round the world again to be installed. The batteries are then shagged in less than 10 years and will need replacing at a 4 figure sum. And it still isn't as efficient as a small petrol / diesel family hatchback.
The worst bit of design has to be Austin / Morris for not using a couple of tubes of seam sealer on the floor / sill seams on the early original Minis.
However by not doing that they made twice as much profit on each car.
Actually thinking about it Austin/ Morris, B.L, /Rover etc have probably made more design errors than any other manufacturer.
The distributor and other electrics on the front of the mini engine very low down with no protection so it all got soaked was a pretty big fail..
Any vauxhaul seats!!!!!
I get the new Vauxhauls quite often to go to head office via Enterprise car hire and after half hour my back is killing me. Not great for a 5 hour drive!
Every one at work gets "Astra back" when going to head office so I'm not alone.
Right there vauxhall standard seats are very uncomfertable.
Apart from the oil supply to the cam lobes the cvh is a fucking great little engine and very sturdy.
Worst car design i've come across personally.....the way nearly all VAG group cars suffer from the loom breaking down where it passes from door to body.....never hear anything about other makes having issues in this area
Sierra Sapphire indicator units
total pish design, the back of them snap off where the retaining spring is located and they just fall out
not good if you're doing 100+mph
Luciano
Luciano
Quite a few cars have stupid headlights that require the wheel/arch liner to come off.
But when it comes to needlessly lengthy routine maintenance work the Citroen DS takes first prize. The front discs are inboard, and can take an experienced specialist 12 hours to swap!!
up on a ramp and you need small hands if not bumper off job the new ones the light comes out
What a shame that would have been
And try changing the air filter and spark plugs
and breathe...
how can you say that?
Another thing that to add to the list that even when an CVH turbo goes bang they cost peanuts to fix!
and neither was there enough give in the plastic to be able to move it out of the way enough
so now i've cut a big section out and then another to fit over the top of it
Rover 600/Honda Accord. Worst car i've ever had by a country mile. That was a pain in the arse to change the headlight bulb but only on one side. The rest of the car was utter shite and was a nightmare to find parts for.
thats why they invented marrigolds to put over the diz and with enough fingers for each ht !
