please help regarding boost problem
Old Sep 17, 2011 | 10:05 AM
  #41
dingla rs's Avatar
dingla rs
Originally Posted by the youth
that may be it dicko, at teesside autodrome the other week I lost over 10 psi of boost I found a 2 mm hole in the dump valve diaphagrm thats all it was!
steve
we said it was dumping on boost between our selfs at tesside while we watched it go passed
Old Sep 17, 2011 | 04:29 PM
  #42
Brendan's Avatar
Brendan
struggling with reality
I had somthing similar on a stage one chip, after fitting a FSE Power Boost Valve Kit.
Ahamed bajoo sussed it out in 5 mins! put the origional one back anf off I went!
Old Sep 17, 2011 | 06:43 PM
  #43
Dicko&Vacant's Avatar
Dicko&Vacant
Right I've tried it today a by easing the throttle in 4th and 5th and I've also tried it with vacuum pipe from boost controller to turbo disconnected, and yep its still the same grrrr
Old Sep 17, 2011 | 06:45 PM
  #44
Mark Shead's Avatar
Mark Shead
Can you fit a genuine Garrett -34 on it and not a fake one.
Mark
Old Sep 17, 2011 | 07:07 PM
  #45
Nosmo-King's Avatar
Nosmo-King
well it looks like a boost leak of some sort then. If you have taken the boost controller out , there is no way the ecu can be cutting the boost electro/mechanically. Lot of mention about the dump valve from others above. Have you removed it to see if its split.
For you to loose 1/2 your boost it must be a huge leak in the TB??
When you loose the boost how does the car run? Rough or quite well considering?
More importantly, how did you do the leak test and what pressure did you use.
Old Sep 17, 2011 | 07:55 PM
  #46
Dicko&Vacant
When the boost drops car still runs fine, to do the leak test we took filter off and blocked off the hose then plumber a t piece into the vacuum hose going to inlet and used compressor to fill the system. Got up to just over 1bar on boost gauge and leak was significant so i dread to think what it will be like at 2bar.
Mark i dont think a cossie style actuator will fit, im gonna fit standard inlet back on and see what its like.
Old Sep 17, 2011 | 08:05 PM
  #47
Nosmo-King's Avatar
Nosmo-King
you must attempt to take it to 2 bar for the test. Trust me you haven't got a compressor big enough to loose the same amount of air as a cosworth boosting to 2 bar then dropping back to 1 at full chat. If you can pressurise the system to 2 bar using a commercially available compressor even with a boost leak then that leak is not enough for you to loose a full bar of boost at 5k. A leak might sound very impressive and loud but it could just be a small one.
You must take the system or attempt to take the system up to the pressure you are using on the road.ie 2 bar.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
