Spec for a 300hp Zetec Turbo?
#81
Bodger of Blackburn
Are all the ho inlets designed for side feed injectors??
If so i would see if this could be modified,
Get some std focus rs injectors, and away ya go,
If you are only wanting 300 have u not considered rs parts??
As said a fOcus rs is easily tuned to 300 on std inlet/injectors/head/internals etc
#82
All i can tell ypu is what ive done to mine is working, its pulling mega power and only at 1.5 bar,
I think i should be able to crack 620-630 bhp by the time the mapping is done
#83
All will run up to 350-380 bhp
#85
Ben
I dOnt know Personally mate, but thats whats in mine from advice because double springs are too harsh
#86
Tbh mate im not sure,
And dont know if you could just buy some uprated side feed ones,
Might be somthing to look into,
If you do convert to top feed just get some vxr injectors, can pick them up really cheap and they will flow plenty for what you need,
Iirc there about 450cc
#90
Side feed phase 1/1.5 scooby injectors fit the standard zetec rail mate, i'm fitting them to mine
Gives a bit more choice, sr20 nissan ones fit as well, just the o-rings to swap about
#92
Yep
Considering most upgrade from standard and the standard greys are good for 320ish bhp iirc then they are quite a good option if you want to keep the standard rail.
#93
you can buy uprated ford side feeds 440cc called f1,s as i think they were made to run in a ford f1 engine back in the day, ian can get you a set about 200 squid
#94
Would this OFAB management be any good to me? Or shall I go with something else?
http://www.ebay.co.uk/itm/Zetec-Turb...item336b634107
#96
Turbocharging Technician
1/4 mile beasty!!!!
Seems like there alot of people saying you need this and you need that on here as always. U don't need to run an mtx gearbox imo mine ran fine with an ib5 for years and in the end the selector bolt came lose and It got stuck in second gear after taking near 50 runs or more at Santapod I only fitted the mtx as it came up in a deal! I still run a fiesta turbo efi inlet! ( I will be changing it to one of Garys in the future)
If I was going for 300bhp I rekon I could build a 12 second car for around Ł2000
#99
This guys talks sense!
But you can still build one cheap and capable of more power in the future,
Lotts of people will have diferent views on what they would do,
In all honesty i dont think there is a right or a wrong way to spec you engine,
I went in a totally diferent direction with mine... And it works
Gearbox's.....
I use to have a s2 with a 2.1 ztec turbo pulling 300+ and the gearbox (std) held up fine,
Started to get a bit noisey after 8 months of constant abuse on fast road driving, but then i broke the car for bits,
#100
Bodger of Blackburn
i have run bc boxes for years and had a few fail, they do take a fair amount of abuse to be fair. the reason i upgraded to an mtx was that it made financial sense to me. also i have equal length driveshafts and an ATB diff, so torque steer is reduced.
i have run a zvh prior to the zetec turbo and on 1.5BAR of boost the rst boxes would last a while of hard abuse, but in the end they all start whining. what do you expect though, they were built for a range of cars from 50bhp upto 133bhp on standard cvh/valencia engines in various guises.
#101
but remember there is next to no weight in deano's little monster which plays a big part into how these boxes last
I think if you were buildinf a car to be used on both road and track then an mtx is the way forward, although you could be lucky with the normal box as it is a bit of a lottery with how the last
