smoking diesel. PLEASE HELP!
fookin diesels
changed the cam belt on my n reg 1.8td mondeo....but been having real problems getting the sucker timed up right as it was beeing a total arse
anyway, now got her running quite, no pinking ect but shes a bit on the rich side its not major but she's smoking a bit when you shove your foot down (didnt di it before the belt change)
now can anyone tell me which way i need to turn the pully on the injector pump to stop this????
also, when they are pinking is that caused by the injector pump being set wrong or the cam sproket being set wrong? or both?
FOOOKIN DIESELS
any help greatly apreaciated!!!!!
FOOOKIN DIESELS
Originally Posted by Jim Galbally
no pinking ect
FUCK
just went out to start her, would not fire then opened the bonnet to find that the header tank has emptyed itself across the engine bay! and the water in the header tank has a slightly foamy look to it. now the cap was done up tight so how the fook has this happend
arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Guest
Posts: n/a
i know when i had some work done on my 306 the system wasnt bled of any air after the pipes were reconected and this kept chucking water out but gasket fine traced it to a lil air bleed valve that must always be opened and bled when doing this wouldnt know if ya didnt have a manual or were french kinna thing try fluashin system airlocks
ok, pretty confident that the gasket ect is fine, washed all the crap off and its definatly come from the header cap. (might have got it cross threaded thinking it was tight.
but there is still the probem of it being a non starter how do these dirty diesel things work????? if the pump has to much advance on it will it 'flood' the chambers like a petrol causing non starting??????
come on guys throw me a bone here
pump timing is very important...
its like ignition timing on a spark ignition engine...
if you get it wrong it wont run properly and wont start!
Go back and time the pump up properly~!
alex
alex
alex
alex
its baisically 2 belts. one from the crank to the cam, and one from crank to injector pump. it says lock the crank with the pin (done that) then rotate the engine till the crank hits the pin and wont turn anymore....then insert pins into the injector pump and cam.
both the injector and cam have a vernier on them and the pin holds the inner bit so you can slacken off and rotate the gear wheel that sits on the belt.
so with the pins in place i run the belt up from the crank, round the vernier and over onto the tentioner. with the vernier bolts slack it says to release the tentioner so that it takes up the slack and pulls the gear wheel round a bit as it does so. tighten the tentioner and vernier bolts. rotate engine twice, re-insert pins and double cheack!
this is what i have done and it still wont bloody work! im getting soooooooooooooooooooooooooooooooooo stressed that i think im going to cry
anyone live near coventry with some tools that can come and help?
Steve Escos
01-10-2015 06:57 AM
