Diff Identification
Old Aug 13, 2011 | 01:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Diff Identification
Can anybody tell me what make of Diff this is please.
Thanks
Steve
Old Aug 13, 2011 | 01:35 PM
dojj's Avatar
dojj
Resident Wrestling Legend
standard for casing, but not sure about whats inside
if it's a 3.64:1 then it's standard cossie 2wd type assuming it's got 108mm flanges
Old Aug 13, 2011 | 01:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Yes its a cossie diff.
I need to know what MAKE if possible
Steve
Old Aug 13, 2011 | 02:38 PM
dojj's Avatar
dojj
looks like an lsd in there but the ford ones seem to be different to those so you'll have to wait for an expert in diffs to come along, and even then, several of them will possibly tell you it's 5 different makes
Old Aug 13, 2011 | 03:20 PM
gibbo frst's Avatar
gibbo frst
Looks the same as my gripper. Comparing the pics. Can't put mine on here as using fone
Old Aug 13, 2011 | 03:22 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Thats two for the gripper then Steve
Now get it back in the car and do a big 11 up the estate
Steve
Old Aug 13, 2011 | 03:23 PM
gibbo frst's Avatar
gibbo frst
If you look in the cup part of the flanges do they have bolts going through.
Old Aug 13, 2011 | 03:25 PM
Moonstone Steve.
yep
http://i685.photobucket.com/albums/v...14-4-11017.jpg
Steve
Old Aug 13, 2011 | 06:16 PM
RSTurboTrev's Avatar
RSTurboTrev
Its an atb of some sort possibly a gripper or a quaffe??
Old Aug 13, 2011 | 06:25 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
same as my gipper
Old Aug 13, 2011 | 06:48 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Its not a Quaife diff for sure.
Steve
Old Aug 13, 2011 | 06:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by ajamesc
same as my gipper
Bigger picture please lol
Also does the diff grind when you turn left and right ?
Steve
Old Aug 13, 2011 | 07:18 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I reckon it's Beefy's
Old Aug 13, 2011 | 07:26 PM
ajamesc's Avatar
ajamesc
Steve
i carnt get the pic bigger its an old one from an old phone and i wouldent say it grinds but dose knock and bang a bit but thats just how grippers are
Old Aug 13, 2011 | 07:36 PM
scoooby slayer's Avatar
scoooby slayer
i had a gripper in my old cos, got a carbonetics in the supra, locks up and 2 black lines just like the gripper but alot less banging at junctions, i thought mine was fooked to when i first fitted it
Old Aug 13, 2011 | 07:40 PM
Moonstone Steve.
The diff is Steve's not beefy's, he is just trying to find out what make the internals are.
Steve
Old Aug 13, 2011 | 07:45 PM
steveboyslim's Avatar
steveboyslim
Gripper or ZF
Steve
Old Aug 13, 2011 | 08:09 PM
dojj's Avatar
dojj
b13 jus had some pics up of a similar diff and that was a gripper
Old Aug 13, 2011 | 08:20 PM
JamesH's Avatar
JamesH
Steve
I think he meant he bought it off Beef!
Old Aug 13, 2011 | 08:28 PM
Moonstone Steve.
I know what he meant
Steve
Old Aug 13, 2011 | 09:03 PM
DAN-Saff's Avatar
DAN-Saff
Steve
The grinding noise is the plates rubbing together when the wheels are traveling at different speeds if it stops making noises it means it needs a rebuild.
Old Aug 13, 2011 | 09:04 PM
ajamesc's Avatar
ajamesc
is it a 7.5 inch diff? as said it dose look like a gripper but on mine i had too mod the diff caseing on one side as the 7.5 inch gripper diff is to big by a very small amount to fit in the diff caseing so a small amount has to be ground out to be able to get it in also had to lift the diff in with the crown wheel lose on the diff or there was no way at all it was going in lol then bolt the crown wheel up when its in there as they are very tight fittiing in the diff caseing!
Old Aug 13, 2011 | 10:07 PM
DAN-Saff's Avatar
DAN-Saff
That's a good point the casing has not been modded. I've managed to get them in all bolted up tho
- here's a couple of pics I've found of when I fitted a quaife
Gripper
You can just about see how much Ive ground off to get them in.
Old Aug 14, 2011 | 01:49 PM
JamesH's Avatar
JamesH
Steve
Old Aug 14, 2011 | 03:08 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thanks for your help guys
I better put the correct oil in it then
Which is ????????
Steve
Old Aug 14, 2011 | 04:08 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Which is ????????
Steve
The cheapest one?
Old Aug 14, 2011 | 04:23 PM
Moonstone Steve.
Which is ????????
Steve
The one Tony said to put in
Steve
Old Aug 14, 2011 | 05:03 PM
ajamesc's Avatar
ajamesc
they use 80/140 in them i use shell 85/140 in mine as its free and what comes out the wall at work lol
Old Aug 14, 2011 | 05:06 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
so we all square then steve mate ?
Old Aug 14, 2011 | 05:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Might send it to Gripper when i collect it from Quaife.
Felt such a plank when they phoned me telling me its not a Quaife diff
I just hope running the wrong oil hasn't Łucked it, as i put EP80 in as you told me it was a Quaife diff and thats what they advised me to use.
Steve
Old Aug 14, 2011 | 06:03 PM
boXXer's Avatar
boXXer
GASH!
i would have been like... "WOO HOO" when they told me it werent a ATB. Grippers are tons better.
And ep80 aint gunna kill a diff in 3 miles is it????? It needs Castrol B373 up its ass.
Old Aug 14, 2011 | 06:39 PM
scoooby slayer
why did you send it in ?
Old Aug 14, 2011 | 08:16 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Who said anything about 3 miles ?
I have done at least 700 miles with the wrong oil in it
Steve
Old Aug 14, 2011 | 08:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The diff has always made a slight grinding noise when turning left or right, but it has become very loud when turning left.
Steve
Old Aug 14, 2011 | 08:23 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I would just like to add none of this is Beefys fault as he bought the diff as a Quaife diff and then sold it onto me as such.
He has offered to pay half of any repair costs as well.
I don't lay any blame at Beefy and he has been great about it.
Steve
Old Aug 14, 2011 | 08:49 PM
-beefy-'s Avatar
-beefy-
Steve
im just praying that u aint fucked it fella,
i personally hadnt realised youd done 700 miles on it by now ....
i think i would of pulled it out sooner if there was doubt ,
hopefully new oil will cure it , or this diff i sold cheap is going to become a big expesnse for me ..........
Old Aug 14, 2011 | 09:07 PM
DAN-Saff's Avatar
DAN-Saff
They are not expensive to rebuild iirc the plates are Ł8 each and if the preload has dropped off it will only be replacing a couple of plates. Last time i had mine rebuilt with new cross shaft it was Ł100 Inc parts but I stripped the unit out of the casing
Old Aug 14, 2011 | 09:48 PM
boXXer's Avatar
boXXer
GASH!
700 miles is no way enough to fuck a diff with the wrong TYPE of oil in it, especially in a road car. Wrong WEIGHT of oil maybe...
Grippers are noisy fuckers as it is, especially on tight corners, as they use preload plates and not planet gears like ATB's. They lock up shit loads nicer than ATB's too so i say you've got a better deal out of it.
as said above, if it DOESNT make noise, then its not working properly.
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
