cosworth engine gone big time? your thoughts
Old 10-08-2011, 09:08 PM
  #41
stevieturbo
C**t
stevieturbo's Avatar
Originally Posted by nugnah
i would suggest maybe, plug end burnt and fell onto piston melting a hole through.
Happened on my cossie, but didn't melt through on No1 cylinder, rebuild though :-(
jas
And that certainly didnt happen.
Lean mixtures and/or detonation cause both the plug and piston to melt. The plug sure as hell didnt do the damage.
Old 11-08-2011, 10:10 AM
  #42
cozmeister
More boost Igor!
cozmeister's Avatar
Originally Posted by DPUD
like proper fooked?
"Yes Tommy, proper fucked"
Old 11-08-2011, 11:29 AM
  #43
DPUD
DPUD's Avatar
Love that Film
Old 11-08-2011, 02:23 PM
  #44
AstoN_B
An eye for detail...
AstoN_B's Avatar
Originally Posted by stevieturbo
Why cant people tell the truth when it comes to these things ?
There is no way in hell the engine will melt anything all of a sudden sitting at a lazy 70mph cruise.
Now if you happened to be boosting the shit out of it before hand, then yes it is quite possible.
But why not give an accurate account of the circumstances leading up to it ?
A bit like a wanker that brought a Subaru in I helped tune. Not running properly, and said it just happened when driving normally. An underbucket shim had dislodged and he was very lucky not to have dropped a valve.
The only way that would ever happen, is if he was abusing the shit out out of it. But of course he denied everything.
His mate was a bit more honest though.
Either way it sounds fucked.
My engine melted piston 4 on the way home from Ford Fair too. EFi cvh. And we were actually sat at 75 and it just cut out. No compression on 1 & 4, and i've seen a hole in piston 4 with a bore scope, although 1 looked ok.
I've since learned that the ECU leans off at cruise above a certain speed, it had been setup last year when a couple injectors packed up, i fitted a new speed sensor day before ford fair as the old one was properly knackered.
This must have meant it could lean off much more when it saw the real speed. Ran absolutely fine for the 9 or so hours before it broke.
Old 11-08-2011, 03:46 PM
  #45
Turbosystems
Super Moderator
Turbosystems's Avatar
pinto's tend to melt no 3 cvh's melt number 4
Old 11-08-2011, 04:20 PM
  #46
Jay,
Sponsor
Jay,'s Avatar
Old 11-08-2011, 04:59 PM
  #47
AstoN_B
AstoN_B's Avatar
which do zetecs melt usually?
Old 11-08-2011, 09:37 PM
  #48
R4N SS
R4N SS's Avatar
1 and 4
Old 11-08-2011, 11:03 PM
  #49
AstoN_B
AstoN_B's Avatar
Well my CVH has melted 4 and possible 1. Go figure!
Old 12-08-2011, 09:42 AM
  #50
nugnah
nugnah's Avatar
it was coming back from a fast car event at santa pod, run what you brung i think, and i was playing with a montego turbo, and then pop running on 3, off boost fine on boost back to 3 cylinders. limped to strensham and called AA who removed plugs and the end of one was missing, eventually had to get head gasket done and the pistin had a big burn mark/dent in it.
jas
Old 12-08-2011, 11:42 AM
  #51
Porkie
Porkie's Avatar
I was thinking the same....
Let me guess... was it going REALLY well just before it blew?
Hope it gets sorted as cheap as possible. Such a pain in the ass.
Old 12-08-2011, 03:29 PM
  #52
andyfisher
cossyfish
andyfisher's Avatar
took head off today guys and number two piston is the one which has melted a wee bit lol, guna fully rebuild a whole new engine now over winter and take my time and do it properly and get it fully set up straight away once built. thanks for the imput anyways
Old 12-08-2011, 04:51 PM
  #53
JonnyBravo
JonnyBravo's Avatar
Someone I know took a engine back to A1 Rallysport that had melted, apparently that let go driving to the shops, later turned out he had been 4 up doing top speed runs up and down the A1
Said damage
Not sure what A1's opinion was but that comment sure helped him out with the rebuild costs
Best to be honest IMO
big_Rad
15-09-2017 09:36 AM
Billy_RS
15
05-09-2015 12:04 PM
track.focus'd
12-08-2015 05:53 PM
wheelwizardrefurbs
06-08-2015 07:40 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
Quick Reply: cosworth engine gone big time? your thoughts
