Fiesta 09 plate tdci zetec s - fuel leak?
thats the overflow pipe, there is a little hole inside the filler neck when the fuel reaches the top of the filler neck it drains through that hole out of that pipe instead of spraying back at you all over your clothes/car
used to have loads of people coming in to fords when capless filler necks came out.if u dont hold the nozzle at the right angle it will come out the overflow pipe.
It's not an overflow pipe, it's actually another breather, so fuel doesn't get stopped due to pressure, I would first check it has not come detached from the filler neck.
Hi, first of all sorry for bumping this thread from dust. My 09' 1.25 Fiesta leaks from small hose next to rear left wheel beneath car when refueling. Leak happens after first "click" on pump. I think it leaks from same hose as from a picture above in this thread. Is that really considered "normal" from Ford dealers view?
Leak happens same way; as in this video:
Thank you!
outlook31
04-01-2010 02:56 PM
