Zetec turbo on the cheap.
Old 16-07-2011 | 02:41 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Zetec turbo on the cheap.
I.e, de-comp plate, do the pistons need skimming? And is there anything else that needs doing internally?
And what sort of results have people had by doing it this way, power figures? Reliable?
Thanks
Ben.
Old 16-07-2011 | 02:50 PM
Dazza@TeamFord's Avatar
Dazza@TeamFord
You need to sort out the crank case breathing for one.
How cheap is cheap though?
Old 16-07-2011 | 03:07 PM
gjh's Avatar
gjh
ARP rod bolts? Just a thought.
Old 16-07-2011 | 03:14 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Cheap probably wasn't the right term to use, I mean instead of going down the forged route.
Old 16-07-2011 | 10:50 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
mines a standard zetec engine with double valve springs . foucs rs headgasket with a massive airsearch t4 turbo, omex management and making 300bhp at the wheels
Old 16-07-2011 | 10:51 PM
MO' BENT RIMS
made 250bhp for about 4 years . now almost 330bhp at fly and its never let me down, just service it on time obviously if i had the chance i would have forged it so i could upp the power
Old 16-07-2011 | 11:27 PM
Rick's Avatar
Rick
black or silver top?
Old 16-07-2011 | 11:33 PM
phil_focus's Avatar
phil_focus
wouldn't matter, 330bhp on a standard 2l zetec is bull. i'd believe it if it was a mk1 frs engine but anything else is bull.
Old 17-07-2011 | 08:51 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I didn't think that would be possible
I think It's silver top, it has an ally cam cover but people fit them to black tops dont they? How do I find out whether It's black or silver?
Ben.
Old 17-07-2011 | 09:14 AM
creator's Avatar
creator
It will either have 1 tension if a silvertop or 1 tensioner and another roller if a blacktop on the cambelt
Hope that makes sense
Old 17-07-2011 | 09:27 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Got it, I'll have a nosey a bit later.
Does this make a difference when it comes to turboing? I know people favour blacktop for big Bhp, but is there anything up with the silvertops?
Old 17-07-2011 | 09:56 AM
luke19790_3's Avatar
luke19790_3
does the focus rs come with double valve springs?
Old 17-07-2011 | 09:58 AM
luke19790_3
think that rolling road is telling porkies
Old 17-07-2011 | 03:30 PM
XRT_si's Avatar
XRT_si
Crank case breathing? I know of a 440bhp Zetec turbo on the original Ford set up?
Old 17-07-2011 | 03:36 PM
gjh's Avatar
gjh
To be fair Mo has showed a rolling road graph that was 270+bhp at the wheels.
Old 17-07-2011 | 03:37 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
Mo...........
Old 17-07-2011 | 03:39 PM
ST Turbo's Avatar
ST Turbo
So do i funny enough! lol! Also mo, so let me get this straight, considering no one makes double vavle springs to fit in a zetec head which doesnt require ££££'s worth of head work, you spent that on your head rather then forgeing your engine... interesting...
Old 17-07-2011 | 04:06 PM
creator's Avatar
creator
Area six do double valve springs that fit straight in
Old 17-07-2011 | 04:09 PM
luke19790_3
does the focus rs come with double valve springs? or do you only need them for high boost
Old 17-07-2011 | 04:10 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Also, 330bhp @ flywheel will not be 300bhp @ wheels in a Series 2 RS Turbo.
Cheers,
Grant
Old 17-07-2011 | 04:14 PM
luke19790_3
did he ?? looked like a kid had drawn a graph then used a camera in space to take the picture.
Old 17-07-2011 | 04:16 PM
woolford's Avatar
woolford
Watching
Old 17-07-2011 | 04:20 PM
creator's Avatar
creator
No focus rs doesnt come with double valve springs
Old 17-07-2011 | 04:34 PM
RS 5tu's Avatar
RS 5tu
focus rs valve springs can be had cheap and will be a good upgrade some arp bolts and a FRS head gasket would be a good base.
although its not just about engine components if you drive like you stole it then it probably wont last long also make sure you get a decent map, even a cheapo AFR gauge would give you half a clue on whats going on.
230-260bhp shouldnt be too hard
Old 17-07-2011 | 04:36 PM
RS 5tu's Avatar
RS 5tu
i believe MOs car would be close to 300bhp, skimmed pistons would give a less reliable engine not a less powerful one.
Old 17-07-2011 | 05:40 PM
Derby_Gav's Avatar
Derby_Gav
I have a 1800 blacktop sat in my garage and a 1600 focus with 125k on.
I keep wondering how cheaply a zetec turbo could be done for. I have been told that blacktop rods are good for 300bhp and I would happily stick a decomp plate on but it's the management side of things where it gets a little pricey.
Is there anyway of doing it with a 5th injector or something similar to the turbo'd zetec mondeos from the mid 90's?
Gavin.
Old 17-07-2011 | 05:43 PM
luke19790_3
while i save up for my 2ltr engine, i'm going fit a 1.8 blacktop with a spacer plate. i'm fitting megasquirt but i guess you could use a fiesta setup
Old 17-07-2011 | 06:30 PM
macdoodle's Avatar
macdoodle
zetec turbo build's can make a bit of a dent in the pocket im doing one at the mo in my restro im useing a 2ltr silver top with a decomp plate 2x multi layerd metal head gasket's 1.8 zetec oil pick up pipe 1.8 zetec sump you need to open the hole's a little bit on the 1.8 zetec flywheel 2x oil return's 1 on the front & 1 on the back im useing a zetec turbo exhaust manifold a custom inlet manifold focus rs fuel rail and injector's OMEX 600 ecu.But if you want to use your escort turbo exhaust manifold you can use an adapter plate which are about £40 off e-bay or you can drill the hole and tap them and you can use a fst rs turbo inlet manifold but you will need to fix a plate on there to fit the head but you can get one already done off e-bay.But the one thing i have learned through this is look into it first make a plan and stick to it
Old 17-07-2011 | 07:01 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
They don't, the ones Ian dose have to have the head machined out for them to fit
Old 17-07-2011 | 07:15 PM
creator's Avatar
creator
Sorry im wrong rob is correct ill shut up now
Old 17-07-2011 | 09:29 PM
MO' BENT RIMS
Cheers,
Grant
mine made EXACTLY 298BHP @WHEELS . PLUS 35BHP FOR FLYWHEEL [THE OP WROTE IT ON GRAPH BUT I JUST SAY 330 AT FLY AND 300 AT WHEELS nobody asks me for exact figure so i just say a rounded figure.
Old 17-07-2011 | 09:40 PM
MO' BENT RIMS
mate the car has skimmed pistons and what looks like a plate in it. but im sure it has a focus rs headgasket.. im no engine builder dude the engine is not a forged block i aint no liar yes its sad that it aint forged and that i should have forged it.. but this is how i got it and its been reliable enough for me and hasnt EVER given me a problem engine wise.i drive it like its stolen all the time and its been perfect. people i know have copied exacty my set up and its proved to be good and they do trackdays etc.. 4 years now and never a problem. . people are scared for nothing i seen em at 360bhp and surviving mines makes 298bhp at the wheels at 16psi on my T4 TURBO and runs like this perfect. when i put the foot down all HELL BREAKS LOOSE! the thing is a weapon.
at the end of the day i see people spending thousands and thousands on a zetec turbo engine but it ends up being slow because they dont spend the money where they need to they sepdn money on the engine but then it still fucks up. i spent the cash on the managament,injectors,head gasket,breather,pipes,t4 turbo,gearbox mapping etc thats what makes the car quicker the way its set up and specced its up to the owner how far to push it .... i didnt spend stupid amount of cash on the engine just incase something went wrong and it blew up! atlease if my engine did blow up the money i spent on parts will still be ok and be good for the engine i get built next
Old 17-07-2011 | 09:44 PM
MO' BENT RIMS
stop being narrow minded. you dont believe it because you aint seen it. no matter what you think mines there doing it and i know people done it.. ask SEVS in willenhall he has a engine built exact same spec as mine and runs 330bhp in a xr2 ... all this time it lasted he crashed the car recently though at a ford show
Old 17-07-2011 | 09:52 PM
MO' BENT RIMS
heres what my engine looks like lads and 298bhp AT THE WHEELS!
Old 17-07-2011 | 09:53 PM
MO' BENT RIMS
Old 17-07-2011 | 09:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
spot on here.
i'm just mapping my zetec turbo now and there ain't nothing cheap about getting reliability.
set of valve springs, steel rods and forged pistons would be a start.
as for breather setup mentioned at one point, i've modified the crank breather and use a catch tank instead of feeding back into inlet. no issues to mention so far.
in my opinion sort out the transmission, mtx75 box is recommended, will hold the power far better than either a bc or ib5 gearbox.
so set aside £1500-£2000 for gearbox conversion including custom shafts and electronic speedo, clutch setup and flywheel.
i'm about 7k in on mine, but there are a few bits i'd like to change and improve already :blub:
Old 17-07-2011 | 09:56 PM
MO' BENT RIMS
running rs engineering injectors
competition cossie race fuel pump
fuel reg
rover inlet
omex management
t4 turbo at 16psi boost [for now]
individual coil pack conversion
pro alloy front mount
focus rs headgasket
etc etc etc
Old 17-07-2011 | 09:59 PM
MO' BENT RIMS
Originally Posted by xr2wishy
spot on here.
+1 if your buildiong something do it properly people otherwise youl be stuuck like me and not be comfortable to up the power like i want to take it to 400bhp but i cant just yet so making it quikcer in other ways like weight different spec turbo ,,better front mounts ,filters, mapping etc etc
Old 17-07-2011 | 10:00 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
skimmed pistons can be fine, run them in my previous engine, piston went in the end lol!
also you say you spent the money on head gasket and yet you aren't sure what headgasket is in there. you're not an engine builder as you've said, could even be a de-comp plate, who knows, doesn't matter i'm sure it's quick enough though.
out of interest, what are the coil on plug units from?
can you find out as my ecu can run COP just need to know some units i can fit in there.
and spending money on pistons and rods is a very good idea, that#'s what dictates how the engine behaves and forged are better than standard ford items.
Old 17-07-2011 | 10:10 PM
MO' BENT RIMS
there from vag audi dude. i have 4 brand new ones spare if you after em pm me i could post em. the head gasket is a focus rs head gasket again not fitted by me.. and as to the forged items your right dude but no point changing anything wehn its worked fine all these years lol but will be when the times comes IF it comes
Quick Reply: Zetec turbo on the cheap.
