rebuilt cossie engine help!
Old Jul 5, 2011 | 08:42 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default rebuilt cossie engine help!
right my mates asked me to try and get abit advice for him hes rebuilt his engine and now its only running 18psi of boost but it was setup to run 26psi? any ideas and also he has a boost sensor harness but is unsure if theres actually a boost sensor as he replaced all the sensors he could find? cheers peeps.
Old Jul 5, 2011 | 08:58 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
anybody got any ideas ?
Old Jul 6, 2011 | 06:08 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
come on someone must know lol
Old Jul 6, 2011 | 07:22 AM
The Youth.'s Avatar
The Youth.
the boost sensor is the map sensor on the near side inner wing, as for the lost boost there could be an air leak, do a pressure test using a air comprerssor and suitable adapter inlet the turbo
steve
Old Jul 6, 2011 | 07:23 AM
pabloXR's Avatar
pabloXR
TA 2008 2009 2012
It might be something as simple as the actuator may have been re connected on the wrong side of the bracket. Loosen the nut on the actuator rod and then wind the rod towards you. (Towards the wing nearest to it). Give it a couple of turns then lock off the nut, then try it.
Hope this helps. Good luck.
Old Jul 6, 2011 | 07:49 AM
Gary F's Avatar
Gary F
If it's had an engine rebuild then I'd personally take it to a tuner for a setup, that way they'll find your lost boost and make sure it's still safe.
Old Jul 6, 2011 | 07:59 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
as gary said mate , dont go adjusting things you aint sure about ,
may well just be a boost leak
consult a tuner or the whole thing may need rebuilding again in the not to distant future lol
Old Jul 6, 2011 | 08:51 AM
steven8489's Avatar
steven8489
Cheers Scotty lad. For some reason I cant start a new thread.
Yeah I am thinking the same about a possible leak as I can hear a squealing noise when I bring it onto boost.
The car has a new style wiring harness on it and When I have built the engine back up the only connector I have free is the boost one. I cannot even remember taking this off because I took photos of everything. I did not adjust anything an the actuator or play with anything i didnt know about to be honest. God knows but i'm sure I will find out .
Thanks peeps
Old Jul 6, 2011 | 09:06 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Tomma,
As said mate, get the old girl down to MSD or one of the trusted tuners and get it set up properly....It'll only cost about Ł150 + the fuel there and back.....
Drop in the ocean on your wages kid
Old Jul 6, 2011 | 09:13 AM
steven8489's Avatar
steven8489
Haha yeah i'm gonna get it taken down bud once I get my other bits and pieces done. Your ramps worked the wonders like dude..
Haha my wages are you kidding me... lol I only have one property hahaha..
You been out in yours recently??
Old Jul 6, 2011 | 09:56 AM
Dicko&Vacant's Avatar
Dicko&Vacant
Maybe you have the pipes from amal valve to turbo and actuator the wrong way round? Simple to do really
Old Jul 6, 2011 | 10:27 AM
martysmartie's Avatar
martysmartie
There is no such thing as a boost sensor, if he has had it rebuilt then he will be running it in, so should not be running any boost. First thing to check is if the Amal valve is working, but more than likely the boost has been turned down anyway because of the rebuilt engine.
Martin
Old Jul 6, 2011 | 10:59 AM
steven8489's Avatar
steven8489
Martysmartie all I have done was replace the head gasket and had my pistons skimmed and pocketed. I have an engine wiring harness which is labelled up from new and on the tag it has boost on it with a connector to be plugged into somewhere. It is not my MAP sensor one as this is already connected.
I have Just noticed that my dump valve is constantly open during tick over..Any ideas??
Old Jul 6, 2011 | 11:02 AM
Stu @ M Developments's Avatar
PassionFords Creator
The "Boost" connector will be a 2 pin one and should be connected to your amal valve which is / was bolted to the top of the intercooler.
Old Jul 6, 2011 | 11:06 AM
Deano's Avatar
Deano
Split diaphragm in your dumpvalve , split boost hose maybe ? Seems odd that youve lost 8psi
Old Jul 6, 2011 | 11:07 AM
Deano's Avatar
Deano
Thats where your air leak is then , should be closed mate !
Old Jul 6, 2011 | 12:25 PM
martysmartie
That makes sense, it's the Amal valve connector as Stu and I mentioned above, with it disconnected you will run lower boost, it's mounted on top of the intercooler.
Martin
Old Jul 6, 2011 | 12:32 PM
It should only be closed on boost mate.
Old Jul 6, 2011 | 12:41 PM
Deano's Avatar
Deano
Really ? Mine was never open on tickover I wonder why !
Old Jul 6, 2011 | 01:37 PM
Are you sure? If it didnt open when you lift your foot, it would never operate and release the boost. Are you sure yours wasnt a twin piston one and just the secondary piston was closed?
Old Jul 6, 2011 | 02:35 PM
steven8489's Avatar
steven8489
Hi chaps thatnks for the advice.. My car has a RS500 intercooler fitted and can i Shi73 find this amal valve? Could it be positioned elsewhere?
My dump valve used to be closed on idle but now open...But once I give it some revs it then closes.
MAny thanks
Old Jul 6, 2011 | 02:43 PM
Dicko&Vacant
Normally with rs500 cooler amal valve is positioned either with a bracket bolted to slam panel or bolted to drivers side inner wing.
Old Jul 6, 2011 | 03:50 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
hope you get it sorted tomma did you find your amal valve mate?
Old Jul 7, 2011 | 12:20 PM
martysmartie
Simply trace the pipes back from actuator and compressor housing, they should connect to the valve, this is assuming they haven't plumbed the compressor housing direct to the actuator in addition to disconnecting the valve?
Martin
Old Jul 12, 2011 | 08:41 AM
steven8489's Avatar
steven8489
JOB DONE....!!!! Well the reason I couldnt find the Amal valve is that it has been by passed... Will this cause any problems and why do people bypass them??
ANyway my boost issue is now sorted. I could hear a high pitched noise coming from the passenger side whin on boost. Into further investigation I done a bit of digging and found out that the problem was my inlet manifold gasket was split. New one fitted and now sweet as a nut.
Time to get on my RL7s and full set of ambers then a trip down to MSD for set up.
Marvellous
Adam-M
Aug 26, 2015 05:53 PM
Gadget
Aug 26, 2015 01:02 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
