Volume on plenumchamber?
Old Feb 11, 2005 | 06:18 PM
robhaugen's Avatar
robhaugen
Default Volume on plenumchamber?
Does anyone know the volume of a 2wd Cosworth plenumchamber with the elbow?
Old Feb 11, 2005 | 06:42 PM
ImaRacing 700's Avatar
ImaRacing 700
No,but it restricts after around 440bhp.
Old Feb 11, 2005 | 07:36 PM
robhaugen's Avatar
robhaugen
Yup, so i heard.. but the restriction is because of the elbow, isn't it?
The idea was to fit a "custom" chamber, like the ones Rainbird, Porkie etc uses but with the same volume as the old...
So i don't have to get the car remapped or whatever.. Or is it a crappy idea?
But the idea of fitting such is mainly because it looks cooler than the old...
Old Feb 11, 2005 | 10:55 PM
robhaugen's Avatar
robhaugen
for anyone that knows... or someone that could be bothered measuring it..
Old Feb 12, 2005 | 05:53 PM
robhaugen's Avatar
robhaugen
no one that knows?
the measurements of a 4wd or a escos plenumchamber would also be helpful..
Old Feb 13, 2005 | 04:08 PM
foreigneRS's Avatar
foreigneRS
Testing the future
hey rob.
if you can wait a bit, i will be removing the 2wd plenum cover and elbow sometime this week or next week and replacing it with a 4x4 one and could measure them for you by filling them with water.
that would be literally just the cover and elbow though, not inlcuding the inlet manifold at all.
anyway, the volume is nothing to do with how much they flow, rather it's more to do that a larger volume has more chance of equal filling to all cylinders.
Old Feb 13, 2005 | 04:31 PM
robhaugen's Avatar
robhaugen
That would've been great..
The idea, stupid or not, was to (try to) make a new plenumchamber and get a better flowing one without having to remap or anything.. So i figured that i would be a good idea to make a chamber about the equal size as the original.. Or am i waaay out here?
Old Feb 13, 2005 | 04:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if it's better flowing, then you'll need a remap. the volume has nothing to do with the flow rate, it's more a factor of diameters, bends etc.
as i said, you can have one that flows the same, but a bigger volume will have more chance of giving equal flow to all 4 cylinders (rather than favouring cyl. 3 as normal cossie ones do).
Old Feb 13, 2005 | 06:13 PM
robhaugen's Avatar
robhaugen
ok... i wish i found enginetheory a bit more exciting so i knew this stuff...
so that's why it can be, and it's said to be, a good idea to use a spacer on the plenumchamber? so all cyls get same flow?
then i might just understand.. or not..
but, when i think about it, you've been very helpful.. i actually got it now.. oh, shite.. there i lost it again. oh well
i noticed you answered my question bout spacers on another post so don't bother answering again..
but thanks anywho.
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Old ford
Jul 31, 2015 06:50 AM
Stu @ M Developments
Technical essay Archives
31
Mar 1, 2011 06:35 PM
ImperialBlueZS
May 17, 2005 10:13 PM
cossiemen
Jun 21, 2004 12:55 AM
