volume on toad alarms
hey guys,
not sure if this is being posted in the correct forum so i apologise in advance if it isnt - mods/admins move at your discretion.
Basically i want to adjust the volume of my Toad Ai606...after hearing numerous of other toad's being armed/disarmed at FITP last weekend mine definately isnt as loud as some peoples.
I have been told there is a certain combination that you have to press on the key fob in order to adjust the volume - can anyone shed any light on this?
Jamie
Jamie
toad alarm ai606
yes mate there is a certain procedure you must press on the keyfob to alter
the chirp volume but first you have to enter the alarms personal pin code
using ign key before it will let you alter any setting you should have a card
with the alarm with the pin code on it if you want the full instruction how to do
it post your email up and i will send it to you
ok
ok
thanks for the reply - imperialbluezs@zsoc.com
also, any idea on how i would go about retrieving a lost pin?
Does this work on all toad alarms??If so can i have the inf as well please.
mickb_13@hotmail.com
OK, even sillier question, how do I found out what model of Toad alarm I have installed as it came installed and the manual seems to be very errr dated and not that clear, is the Ai606 a newer model?
If it helps, mine when it goes off is one of them that makes all sorts of different siren noises Very annoying!
