Hub nut direction - which side of car?
Ok guys,
I've taken all 4 hubs off my Saff Cossie, powdercoated and replaced with new bearings. I know all 4 went back together how they came off, but are they correct, as from what I've just read on the net I'm not sure they are
Both drivers side hubs are left hand thread, is this correct??
It makes sense that the left hand threads would be on the left and the rights on the right so they wont undo while travelling forward , sounds like someone has had it apart before and maybe got them mixed up mate
Resident Wrestling Legend
The rear hubs are interchangable left and right as are the fronts but the fronts both do up as normal and it's only one on the rear that's the wrong way round. Front hubs really need to be done up when they are on the car but I've simply stuf them I. A vice and bolted a brake disc and caliper to the hub and jammed a screwdriver into the vanes of the disc to stop it from turning
Dojj, surely the fronts aren't interchangeable due to the caliper mounting etc? The fronts are easier to do up in a vice due to the nut doing up from the back!
Can you confirm which side rear is lht?
The bit that you are tightening up isn't handed mate, that's because it slots inside the knuckle of the hub where as what you are refering to is the hub face
not too clued up on the 2wd stuff though but would like to know as I'm about to change a set of bearings on mine
JoeyBoyden
04-01-2024 02:36 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
track.focus'd
12-08-2015 05:53 PM
