what ecu to buy
what ecu to buy
as a both time has come for me buy a ecu for my 4x4 focus cosworth ,its gna run a t4 turbo technics turbo with external wastegate but un sure what ecu to go for i wana run around 450 brake any info would be good as im new to cosworths
cossie fan (unluckerly)
best to just talk to who ever you will take it too to map it as everyone has different ideas as to what is best to use lol i have autronics on mine as m.a.d did my engine!
Half Rice Half Chips
The latest MS uses a push fit board which means its a better quality ecu, rick & rob_dohc are the fella to talk to about this as im considering getting shut of my v4 and going for one of these
I was thinking this but doesn't includ launch controll anti lag does it??
My mate got his car mapped by them they are good, he got launch control, anti-lag, coil pack, cloosed loop, and air injectors fitted and live mapped by them.
But my brother went a different way and fitted a haltech ecu which you can learn to mapp yourself which we did a bit but then we took it to sitech racing in scotland who finished the mapping and its great ecu with new loom
Any ecu with the features you want, and whose mappers have your confidence in them to do a good job, imo it's about 10% ecu and 90% mapper, but each mapper will have their favourite ones, some unfortunately for financial reasons over quality so look around wisely.
And despite what is written here incorrectly some can plug direct into the cossie loom with a patch lead, but would likely not work with the 4 lug crank sensors.
Haltech definitely runs off all factory sensors if required via a patch loom.
Adaptronic is another pretty cheap ecu. Dont know if it will work off the 4 tooth. It should be able to though.
Isnt hard to throw on a 36-1 crank pulley if required.
But as others have said. You need to be using a system whoever is mapping it is familiar with.
DixieTheKid
11
06-06-2020 11:20 AM
DixieTheKid
14-09-2015 09:04 PM
