what bulbs ya using....
Old Jun 18, 2011 | 01:30 PM
Slackbladder's Avatar
Slackbladder
Default what bulbs ya using....
sapphire cossie.... anyone know what best bulbs to use in front??
Old Jun 18, 2011 | 01:37 PM
martysmartie's Avatar
martysmartie
Are you talking standard or to uprate?
Head/Main beam are H4's, trouble with the latter is if wanting to upgrade you need to consider the age of the wiring, pulling through more power than standard is a reciepe for disaster due to the demand on the wiring.
Martin
Old Jun 18, 2011 | 03:22 PM
I used to swear by the auto express award winners, Philips Extreme, and Osram Nghtbreaker, these always scored 1 and 2 respectively in the tests.
Until one day whilst in Thetford norfolk whilst watching out for the zombie attacks I noticed a bulb was blown, on the astra, which previously had used extreme and nightbreaker at different times, I popped into halfords and bought a Halfords Extreme brilliance H4, in a purple box about £20, but was on a bogof offer at time, my god mind blowing difference it made, even though AE didn't rate them!!
These are also in my cossie in the main light, and ring 130watt in the inners.
Previous to this on the astra I had cleaned the insides of the lenses and reflector with correct cleaner, and used HID, extreme(orignal ones were best), silver star(renamed nightbreaker), HID gave next to no output on main beam as was too high in relation to the front, so took it off, the halfords bulbs were by a hell of a long way the best, and last a lot longer too.
I do a lot of night driving, but I would seriously consider HID for the cossie as it has a seperate main beam inner so you could reap the low beam benefits of HID, failing that the halfords ones mentioned would get my vote.
As eluded to you will get a most noticeable benefit by simply using relays and new wire to each light, due to age of wiring, done this on 4 sierra and all improved a lot even with std bulbs.
I use two relays inside each light, one for dip one for main, I kept them seperate so if one dip failed I'd still have the other, I ran heavy gauge wiring direct from the battery live and earth to the relays inside each light after drilling a small hole in the rear cover of each light.
Old Jun 18, 2011 | 05:48 PM
Rob Virgo's Avatar
Rob Virgo
got a set of dip/high hids,39 dollars from the states,great quality and also got a full briaded harness inc relays for 15 dollars.picked 4.5 k i think so as to give white light and not chav blue.
looks very different and daylight to night time difference on the morretes
Old Jun 18, 2011 | 06:43 PM
mick's Avatar
mick
with tabetha on this one, i use osram nightbrakers in the bm but found the halfords extra brilliance ones better in the sierra..
Old Jun 18, 2011 | 07:22 PM
Slackbladder
halfords extra brilliance it is!!
thnx all
Old Jun 18, 2011 | 07:51 PM
Bullett's Avatar
Bullett
ring xenon plus are good and cheap too.or the osram as said
Old Jun 18, 2011 | 08:02 PM
Did you use H4-3 or H4-4 ?
Kyle Langford
27
Aug 5, 2019 07:54 PM
Steve Escos
Oct 1, 2015 06:57 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Caddyshack
Aug 19, 2015 07:29 PM
adriansaleem
Aug 1, 2015 09:28 PM
