DIY Window tint, worth it?
±§~Quadzackular~§±
Hello,
So some of you know i got a ZS now and it does look abit shit without the tints, so is it easy to do this yourself in a cheap way or better to leave it to someone who knows?
Many Thanks Eigdoog.
±§~Quadzackular~§±
lol does it keep coming off or something? maybe it dont stick or the bubbles are everywhere.
Does anyone know a rough price to get it done by someone?
theway to do it is.
cut it to shape or as close as you can, bigger ideally,
then use a spray bottle like you do the flowers with and mix, a drop of johnsons baby shampoo with water,
then it should spray like a film then and not like water beads
put the tint on the outside of the window still with the film on the glue, but the glue side facing towards you
then get a hot air gun and heat it until it moulds to the window shape, allow to cool while you clean the window and spray with the soloution above.
take film off the glue side and spray this,
then apply the tint to the inside of the glass and it should fit the window shape (hopefully)
squeege out the water from the middle outwards while heating gently.
if it front windows youll need to take the window trim off, and dont use windows for around 48 hrs
As above, get a felt squeegee off ebay (about £2) or use something soft to avoid marking/scratching the tint, heatgun or hairdrier is a must to shape it to the glass unless its a perfect flat piece of glass (which i doubt it is) you will get lines, crinkles and bubbles without a heatgun, much easier if you take the glass out of the car first
As above, you need to heat shrink it to the glass. I've done a few cars now and am by no means a pro, getting quite good at it though! If you don't have loads of patience or a steady hand then I wouldn't even bother attempting lol. Have a look on youtube at videos of heat shrinking, will give you an idea of what's involved
±§~Quadzackular~§±
Im not going to take the glass out lol i dont have time for things like that.
Nor will it get put back together right...
So its take your time and do it right i guess.
Thanks for the help! I think ill get some and do it!
Anyone know what % i can have? I think its 25% at the front and anything at the back, does this included the back window?
You can't put anything on the front side windows as you will find that factory glass is tinted as standard and is at the legal limit, but you can put what you like on the back side and back window. I've got dark smoke and you cant see in, visibility out is still ok though.
±§~Quadzackular~§±
Spelling Club King!
If you put any film whatsoever on the front screen, or front side windows, then it's technically illegal. Manufacturers get away with putting a variety of tints on the front sides, but for whatever reason you can't alter it. In my experience you're very unlikely to get pulled for very lightly smoked front windows. You can do what you like on the rear, and rear side windows.
I've also never seen a DIY tint job any where near as good as the pros do, so wouldn't recommend trying it for your first time. If you're set on trying it yourself, you have to make sure the glass is scrupulously clean, any tiny bits of dirt will show up. You also have to be in a dust free environment when you do it - I dispair when I see mobile fitters doing it in the middle of a field at a car show!
±§~Quadzackular~§±
±§~Quadzackular~§±
http://cgi.ebay.co.uk/Black-Tinted-W...#ht_2456wt_907
and all i have to do is put it on myself, might give it ago for a tenner.
±§~Quadzackular~§±
I might not do anything yet or just paint the back window in black hammerite as it seems the quick easy thing to do
