How much pressure in cossie power steering system?
Old 29-05-2011 | 04:57 PM
rog's Avatar
rog
Default How much pressure in cossie power steering system?
Need to buy correct hoses and fittings for my power steering system, pump to rack, anyone know a rough psi output of the PAS pump?
Old 29-05-2011 | 05:01 PM
GribbiN's Avatar
GribbiN
1150psi
Old 29-05-2011 | 06:16 PM
rog's Avatar
rog
Ok thanks, I will get on the case to Pirtek I think!
Old 29-05-2011 | 09:41 PM
I measured this years ago when running flexy pipes and am 99.9% sure it was around 400psi.
Old 30-05-2011 | 11:18 AM
rog's Avatar
rog
Thanks for the replies, interesting to hear where the 1150 psi figure came from, bit of a difference from 400psi.
Old 30-05-2011 | 03:19 PM
iansoutham's Avatar
iansoutham
OCD Victim
Not sure on the Cossie, but a MK2 Focus PAS pump is rated to 104 bar according to the sticker on the side of it. Multiply 104 bar by 14.5 and you get 1508psi, so 1100psi is not that far fetched.
Old 30-05-2011 | 03:24 PM
chaffe's Avatar
chaffe
Turbocharging Technician
either way its just normal hydraulic hose you need, pirtec will be cheaper than hydrasun for sure
Old 30-05-2011 | 03:29 PM
rog's Avatar
rog
Thanks, yes Pirtek is getting a visit tomorrow, I intended to use crimped fittings for the pressure side and re-ueseable for the return, but I'm wandering if i can get away with re-useable for the whle lot.
Old 30-05-2011 | 03:30 PM
Ben26's Avatar
Ben26
bloody hell thats some crazy PSI , i wish i had PAS !
Old 30-05-2011 | 03:33 PM
rog's Avatar
rog
Lol that's nothing!
Old 30-05-2011 | 03:54 PM
chaffe's Avatar
chaffe
the return can just be hose clipped, but the pressure will have to be at least single wire crimped hydraulic, even that will be good for 3000 psi, far more than you will ever need
Old 30-05-2011 | 04:34 PM
M K's Avatar
M K
Cosworth pas pump is around 90 bar and the grp a/wrc zf pumps were about 95 bar iirc
Thanks
Marc
Rob Wells
Ford Mondeo Including ST
18-04-2023 01:19 AM
JK12
33
26-04-2021 01:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 02:03 PM
hopper350
04-09-2015 01:53 AM
CrOwSoN15
14
03-09-2015 01:21 PM
