Haynes Manual Translation !!
![Talking](https://passionford.com/forum/images/icons/icon10.gif)
TRANSLATING THE HAYNES MOTOR MAINTENANCE MANUALS
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: Clamp with molegrips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with molegrips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read right through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Prise off...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (giant economy size).
Haynes: Retain tiny spring...
Translation: PINGGGG - "Jesus, where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a plaster or two).
Haynes: Lightly slacken...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with molegrips then beat repeatedly with hammer.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned you!
Haynes: One spanner rating.
Translation: An infant could do this... so how did you manage to **** it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact, that would have been more use to you).
Haynes: Three spanner rating.
Translation: Make sure you won't need your car for a couple of days.
Haynes: Four spanner rating.
Translation: You're not seriously considering this are you?
Haynes: Five spanner rating.
Translation: OK - but don't ever transport your loved ones in it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer...
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife, "Yep, it's as I thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer serious abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Difficult to reach ...
Translation: Assembled at the factory and never meant to be touched.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Haynes: Everyday toolkit
Translation: RAC Card & Mobile Phone (but don't forget your molegrips and hammer!)
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with molegrips then beat repeatedly with hammer.
Haynes: As pictured in figure...
Translation: Do you see that grey bit next to the other grey bit in the picture? Excellent, but your car will look completely different.
Haynes: Index
Translation: List of all the things in the book, bar what you need to do.
HAYNES GUIDE TO TOOLS OF THE TRADE
HAMMER: Originally employed as a weapon of war, the hammer is nowadays used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
MOLE-GRIPS/ADJUSTABLE spanner: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake-drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls in about the time it takes you to say, "F...."
HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front wing.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
AVIATION METAL SNIPS: See hacksaw.
INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate as 105-mm howitzer shells during the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper- and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel burning power plant 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact spanner that grips rusty bolts last tightened 30 years ago by someone in Dagenham, and rounds them off.
PRY (CROW) BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 pence part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Engineering Terms
* A NUMBER OF DIFFERENT APPROACHES ARE BEING TRIED
We are still pissing in the wind.
* EXTENSIVE REPORT IS BEING PREPARED ON A FRESH APPROACH TO THE PROBLEM
We just hired three kids fresh out of college.
* CLOSE PROJECT COORDINATION
We know who to blame.
* MAJOR TECHNOLOGICAL BREAKTHROUGH
It works OK, but looks very hitech.
* CUSTOMER SATISFACTION IS DELIVERED ASSURED
We are so far behind schedule the customer is happy to get it delivered.
* PRELIMINARY OPERATIONAL TESTS WERE INCONCLUSIVE
The darn thing blew up when we threw the switch
* TEST RESULTS WERE EXTREMELY GRATIFYING
We are so surprised that the stupid thing works.
* THE ENTIRE CONCEPT WILL HAVE TO BE ABANDONED
The only person who understood the thing quit.
* ALL NEW
Parts not interchangeable with the previous design.
* RUGGED
Too damn heavy to lift!
* LIGHTWEIGHT
Lighter than RUGGED.
* YEARS OF DEVELOPMENT
One finally worked.
* LOW MAINTENANCE
Impossible to fix if broken
Haynes: Undo...
Haynes: Compress...
Haynes: Inspect...
Haynes: Index
Engineering Terms
* ALL NEW
* RUGGED
* LIGHTWEIGHT
One finally worked.
* LOW MAINTENANCE
Done that one a few times
Hurts like hell
![tiff](https://passionford.com/forum/images/smilies/punchballs.gif)
so true done it many a time
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
