n reg rs2000 rear wheel bearing
hi all, justa quick one, a mate of mine has asked me to do his rear wheel bearings for him on sunday coming, now i just need some clarification as to whether the motor factors is gonna be supplying the right part?
they are trying to give me a taper bearing kit with 2 sets of bearings and 2 cups etc like you would find in a car with drums, now i presume that as the car has discs that it should be a single cartridge type bearing?
am i wrong?
hope someone can help!
cheers
chris
am i wrong?
cheers
chris
The Special One
Unless they've been converted, most N-Reg RS2000's will have drums on the rear.
I've got an N-Reg RS2000 and have just completely rebuilt the rear brake and hub assembly.
If it has drums, what they've supplied is correct. If it discs, then it's wrong.
The Special One
MK5 and MK5 Facelift RS2000's had rear discs, as did the first run of MK6's (very early ones). After that they switched to drums.
I thought all MK6's with discs were M-Reg only, but perhaps some very early N's were too, or could have been registered late.
The one I have is a November 1995 N-Reg (so a fairly early N) with rear drums and 4-wheel ABS.
great, there is no real clarity in here!
it is a disc model and they are adamant that they are taper bearings and not cartridge?
looks like ill just get what they tell me is right and hope for the best.
Moderator
just do a parts request on fordpartsuk which as they ask for your vin number and they will tell you in their reply what bearing kit is needed ,I reckon its the set the same as with the drums tbh ,as my garage did my bearings last winter so I did not see what type they were.
Mike Im pretty sure your right all 4x4s had a rear disc beam as standard as I have never seen one without it
Right pain in the arse to make as well!!!
am i wrong?
cheers
chris
am i wrong?
cheers
chris
cheerS gary
AKA shrek
Must be the same as the 130hp xr3i's then,the pisspots as they were known!!!very rarely we made them so that figures as I doubt that many were sold in comparison to poverty spec models.
Is yours originally an M or N plate though?
borboyous
22-08-2015 11:17 AM
