Noise from YB head *video added*
#41
ive had a cossie make a similar noise, was nicks from msd, turned out crank pully was tight as but had nipped the washer thingie enough and that made a right noise like tappets from the top end but it clearly wasnt!!!
#43
Thanks for all the replys i've only just got a chance to get on the net (Ibiza sun)
Head thickness is some thing that people will all ways disagree on i ran my last head which was 137.5mm ish with no problems be it I used a thicker head gasket than the one currantly on the car.
I can't see valve contact causing the problem as the pistons have deep valve cut outs
My old man has stripped the cam cover off to have a look and found some scores on the cam lobes we are both thinking may be sticky tappits????
But don't know how this makes sense but will be checking this out:
I remember tightening the crank pulley bolt to 110ft lbs then realising it should only be 100ft lbs but left it as is.
thanks again for all your help
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
