RIGHT...whats so great about gt turbos'
what is wrong with the garret t series turbos or the hybrids, from what i.ve heard the gt turbos are more fragile, hense the need for a gay dump valve.
Please could someone write a simple table comparing the gt series to the garret t series and what power and engine mods u need per turbo.
I have tried searching but its just the rubbish saying my turbo is better than yours and i am looking to upgrade turbo soon. Cheers for your help. Luke
But i though thats why they introduced the 360 bearing on the gt series. So if i was to run greys group a head head, aiming for around 450bhp what gt turbo would i be looking at also what prices are there? I was going down the TT T38 ROUTE
if your looking for a gt series garrett for 450bhp then id go for the gt3071
if you want something else then a borgwarner k27 or a borg s2b as it running a lower inducer will help with spool
I.ve never heard of a borgwarmer turbo???? Do u know rough prices for the gt3071 and are they 360bearing turbos and not wet bearing? Cheers luke
They fitted the gt 3071 to focus or u mean that brand of turbos? I was hoping for something with some kick, what power range does the gt3071 go from and too and does it need any mods to bolt implace of my t3?
borg warner made the T5 gearbox in the sierra cosworth and the turbo division used to be KKK turbos, as used in porsche 911 turbo, audi s2, golf gti 1.8t, they have a new range of aftermarket turbos to challenge the best from garrett. roller bearing are much better for spool up time than 360 degree plain bearing is my understanding.
does anyone of here sell them and can give me a price? I guess the borg warner turbo's are cheaper but where do i go about getting one from
easiest place is america to get them.
borgwarner turbos arnt a new thing, they have been used of performance vehicles for years, its just the uk is only just catching up im afraid.
the reason they are so popular is the price of them.
to give you example
a rollerbearing gt42(1000bhp) turbo costs around £2000 in the uk
you can buy a borg warner s475 turbo for £450, they have the same compressor wheel size and a range of rear turbine wheels to suit your needs.
they also flow 1000bhp aswell.
A test was done in america where both turbos were run on the same engine and made the same power(give or take a couple of bhp) at the same boost, yet the borg spooled 400rpm earlier!
also the borg isnt rollerbearing so it runs a nice simple large shaft journel bearing setup, so its cheap to fix and also you dont need to run water lines which in turn helps keep engine water temps down
many people may think this is either false or if its true why isnt everyone running them.......well ford guys are only just working out divided rear housings yet us jap guys have been using them since the 80s
to give you example
cossie fan (unluckerly)
to give you example
to give you example
I though bearing turbo's were superior?
actually you will find a few things you didnt know.
1. rod bought that turbo 2 years ago when he didnt know anything about them
2. he wanted the s475 with a t4 rear housing, what he actually recieved was completely the wrong turbo, turned out to be the smaller shafted s300 series turbo with to small a compressor wheel, hence never made the power it should.
3. he realised his mistake and then tried to sell it to me and danny from ep but we looked at the spec and saw that it would be no good for a piston engine(wouldnt be to bad for a rotary) due to its front to rear wheel ratio.
the large turbine wheel meant it spooled similar to the gt42 but the smaller comp wheel meant it wasnt making the power as predicted
Rod will back me up on all that as i still have the pms from him i think.
using a proper s475 will give the results i mentioned
for example http://www.youtube.com/watch?v=YS8w0dFd-zk
but even this turbo i speak of is old tech now, the new EFR series is much more effecient for its comp wheel size, to the point like the gtx series you can shrink your wheel and still maintain the same flow.
the only think holding back the EFR series at the moment is the lack of wheel options but that will come in time
so the s475 bolts straight on in place of the t3. What size options are there, .63 .70?? I need a turbo which safely runs at 450as my grey injectors run out at 450. If i was to buy one what spec should i ask for?
no a s475 is in a different league from what your after and wont work with your engine.
Some pm'd me last night asking exactly the same question as yourself so ill just copy and paste my response, i was at work so didnt have time to reread it or check its all spot on so excuse any spelling/grammar mistakes
'one of the issues you will come across with other turbo manufactures is that they built using 21st century tech.
That means alot will come with divided rear housings for better spool, but the 4x4 cosworth doesnt come with this due to cost.
strangly the 2wd manifold is divided but then they used an elbow to remove that, again probably to save money on the turbo itself(tight buggers)
so looking turbos, my suggestion is either go for a borgwarner S2B t3 turbo with a .76 rear housing, will flow about 460bhp at 2bar
or go for a masterpower turbo, alot of people assume these are ebay turbos, but infact the ebay companies just bought the compressor housings and not the actual turbos themselves
With that in mind, they do a larger range of small turbos in your power range
802128-048 T57 O-trim / .48a/r
comes undivided rear housing, less restrictive 4in inlet(looks like a gt30 from the front)
it has quite a low trim so should spool up pretty quick yet still flow good power
these cost about £500 delivered to your door
these are a few details on them
Compressor:
-A/R .70
-Air inlet 101.7
-Air outlet 64.0
-Inducer wheel 56.5
-Exducer wheel 84.0
-Trim 45
Turbine:
-A/R .68
-Inlet T3
-Turbine housing undivided
-Discharge outlet 5-Bolt/M8
-Exducer wheel 58.5
-Inducer wheel 74.0
-Trim 62'
Compressor:
-A/R .70
-Air inlet 101.7
-Air outlet 64.0
-Inducer wheel 56.5
-Exducer wheel 84.0
-Trim 45
Turbine:
-A/R .68
-Inlet T3
-Exducer wheel 58.5
-Inducer wheel 74.0
-Trim 62'
some good info there cheers mate, but im still not convinced about the gt3071 turbo let alone borg turbos. U say it flows up to 460bhp but what is the next turbo up from this as i may get bigger injectors in future and get more head work done. Do u sell these turbos as 500quid seems like a bargain to me compared to price of gt3071.
Happily retired
Ive never had a Borg 475
I did indeed buy a BW 400SX it was sold to me as a 850bhp version. When we finally came to test it against the GT4202 it was circa 80bhp down, worked well but not the Power we required. I had the Turbo for some time so no comeback. Further investigation revealed that the 850 version did not come in my flange size I had been given false gen. The Turbo would be great for Power up to 750bhp.
I now have a GTX42 fitted but im changing to the latest BW EFR range of Turbos. MADAde is the testbed. Mark is now using BW Turbos on EVO's & getting great results. Read PF mag this month theirs a full article in there. The EFR is the first ever twin scroll designed from scratch, the others are modified single scroll.
Performance Ford June 2011
' EFR might be shorthand for 'engineered for racing' but these new turbos have so nuch to offer that the next few years could see the EFR turbo become first choice for road & race cars across all marques.'
![](https://passionford.com/forum/images/smilies/shocked.gif)
rod have they got an efr turbo for around 450-500hp? My engine will be set up for about 450 but i want a bit of room for improvement. Also any idea on cost?cheers
Who is mapping your car?
I appreciate your wanting to expand your knowledge, but only use the information given on here as a guide. I see your from Kent, and whilst he is not exactlly a stones throw away, I would take a trip to see Mark @ MAD.
I havent decided yet mate but was thinking about taking a trip to blackpool! But it all depends on suggestions of the tuner and price really. Once i decide on turbo i can start looking into it more but the reason for this post was to find out about turbos to start with.
Right ive found the two turbos from the efr range that range within my power, this is the first,
Borg Warner EFR 7064 Turbo (300-500 HP)
The Borg Warner EFR 7064 is the 4th size (#4 of 7) turbocharger in the high performance EFR line up. The 52.2mm inducer, 70mm exducer Fully Machined Wheel (FMW) compressor flows 56lb/min & will support 500 HP. Truly remarkable for a wheel of it's size. Extremely quick spool & high HP output in a compact frame size. Unrestricted 3.50" air inlet, 2.00" slip-on coupler outlet with integrated Vband option allows use of a standard silicone connector or burst-proof V-band flange & clamp. The BW EFR 7064 is suitable for rally, drift, road racing, auto X, street & drag.
BorgWarner EFR (Engineered For Racing) Series turbos are purpose built units for the performance market & meet the needs of the next generation turbo consumer. Revolutionary from the ground up, each incorporates a long list of features never before seen in a single package. All old technology has been thrown away completely & the result is a whole new breed of turbo, packed full of cutting edge advancements. Great emphases has been put towards a more compact design, making each EFR the ideal choice for applications with limited space available. Outstanding ease of installation & budget friendly (thanks to their 'total package' platform) every EFR eliminates the need to purchase/fabricate/install a separate blow of valve & related flanges/tubing due to their already integrated BOV. The internally wastegated units present another large advantage in savings & install simplicity by eliminating the need for an external wastegate(s), related fab work & otherwise cumbersome materials.
Compressor Features
* Low inertia, Forged Billet Aluminum Compressor Wheel w/ Extended Tip Technology (ETT) provides the ultimate in response & extreme durability in high pressure applications.
* Speed sensor mounting provisions
* Built In BOV Included (All EFR compressor housings incorporate an integrated BOV)
* Boost Control Solenoid Included
Compressor Specs
* Compressor Wheel Inducer: 52.2mm
* Compressor Wheel Exducer (OD): 70mm
* Max Flow Rate: 56 lb/min
* Housing: 3.5" inlet, 2.0" hose coupler outlet w/ integrated Vband option
Turbine Features
* Gamma-Ti turbine wheel cuts turbine inertia up to 50%, dramatically improving turbo response & permitting high rotational speeds.
* Solid Stainless Steel Investment Cast thin wall turbine housing for extreme durability, huge weight reductions & lowered thermal inertia. Very smooth internal channels promote peak flow.
* Adjustable Internal wastegate actuator Included (internal wastegated units only)
* Large internal wastegate ports handle the flow requirements of high performance engines. (internal wastegated units only)
Turbine Specs
* Turbine Wheel OD: 64mm
* Available Housing Option #1: T3 Single Scroll Inlet, 3" (92mm OD) V-band downpipe discharge, .83 A/R, w/ Internal Wastegate
* Available Housing Option #2: T4 Divided / Twin Scroll Inlet, 3" (92mm OD) V-band downpipe discharge, .92 A/R w/ Internal Wastegate
* Available Housing Option #3: T4 Divided / Twin Scroll Inlet, 3" (92mm OD) V-band downpipe discharge, 1.05 A/R, Non-Internal wastegate. (for use with external wastegate only)
Center Section
* Dual Row Ceramic Ball Bearing Design (extreme durability & the lowest friction / fastest spooling bearing design produced to date)
* Built-in -4 AN oil control orifice included (no restrictor needed)
* Water-cooled ( water-cooling is recommended but not mandatory)
* Double seals on both turbine and compressor end for extreme durability & resistance to oil seepage
Note: #1 The turbo part number changes based on the turbine housing selected. The following part number(s) apply to this turbo. P/N: 179355 (T3), 179389 (T4 w/ WG), 179391 (T4 Non-WG)
Note #2: ALL of our Borg Warner turbochargers are fully balanced, brand new units from the factory & include BW's 1 year manufacturers warranty
Second is BW EFR 7670 turbo. (375-600 HP Rating) "
The Borg Warner EFR 7670 is the 5th size (#5 of 7) turbocharger in the high performance EFR series. Utilizing a 57.2mm inducer, 76mm OD exducer FMW compressor to pump out a huge 64 lb/min of flow that supports up to 600 HP. Extremely quick spool & high HP output in a compact frame enables it to occupy only minimal space while producing a potent punch. Perfect for mid to high boost applications up to 45+ psi. Comes with the EFR mid sized ported shroud (compressor housing) with 3.5" air inlet & 2" outlet. The BW EFR 7670 is the perfect small displacement engine turbocharger for drift, road race, time attack, street & some drag that require 600HP of flow capability.
Compressor Features
Compressor Specs
* Compressor Wheel Inducer: 57.2mm
* Compressor Wheel Exducer (OD): 76mm
* Max Flow Rate: 64 lb/min
Turbine Features
Turbine Specs
* Turbine Wheel OD: 70mm
Center Section
Note: #1 The turbo part number changes based on the turbine housing selected. The following part number(s) apply to this turbo. P/N: 179351 (T3), 179390 (T4 w/ WG), 179392 (T4 Non-WG)
Note #2: ALL of our Borg Warner turbochargers are fully balanced, brand new units from the factory & include BW's 1 year manufacturers warranty."
Any opinions on these there expensive too $1,800
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
my opinion is why not stick with something that you know has been used time and time again? If it aint broke why fix it
theres the T series, GT series, and now the GTX series
Whats the gtx series? I.ve tried finding a good website for the gt series that lists the different specs but cant seem to find one
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
Compressor Features
Compressor Specs
Turbine Features
Turbine Specs
Center Section
also flows about the same aswell
benefits of it is a better turbine wheel over the garrett as the gtx model is just a gt with a different comp wheel.
the problem you have is your looking at a turbo that was optimised by BW as a twinscroll turbo(as rod mentioned) then using a single scroll, not saying you shouldnt but for the cost of these turbos its something i would be aware of.... a benefit your not using.
overall it will spool a bit earlier than a gtx3071 and make the same power
The next turbo you looked at is similar to the gtx3076 when we look a the compressor wheel, but then runs a larger turbine wheel, again the turbine wheel is better than the garrett but its extra 10mm of size should offset its original gain in spool.
the benefit of a larger turbine wheel is less exhaust gas backpressure which in turn means its easier to get gas out of the engine which increases VE of the engine..
Borg warner looked at it as....the more into the engine, the more coming out so increased there exhaust wheel as they increased there comp wheel.......garrett just stuck a high flowing comp wheel on a low flowing exhaust wheel.
Most people who buy garretts get over this by either not knowing there is a slight loss of potential VE or not concerning themselves on it.
For me id rather optimise both sides of the engine
So overall, do i think the EFR range is better than the GTX range..........yes by a long way.
Do i think its worth you spending your money on........well only you can ask yourself that, personally if your not looking to spend big or have a budget you want to work to then no i would choose something different
all depends on how much you want to maximise your engine setup, you can cut corners everywhere but it will limit an engines potential
also luke another couple of comparisons.
because the bw is running a lightweight gamma wheel the 'off/on' response is better....less weight to speed up and slow down.
when tested a bw hit the same level of boost as the gtx(24psi) 0.500sec quicker
this is when your at a rpm where putting your foot down will mean you hit full boost.
for example 4krpm with a t34 or a 5krpm with a t4
looking at them in detail shows that the compressor wheel on the gtx is a little bit better than the one of the EFR, but the turbine wheel on the EFR is massively better than the GTX when means overall it produces better numbers.
at 1.5bar on a 2.0 piston engine it makes 17whp more than the gtx through less exhaust backpressure, but with everything, nothings for free, so straight up dyno runs you will expect to loose 200rpm of spool
googled the manifold and your right......its divided all the way through!!
what the heck are people running non divided turbos for then?
since cosworth engines do generally run alot of boost the need compressor wheels at are very effiecent at that level so you can look at either the:
k27 will flow 520bhp, is journal bearing and has a t3 turbine inlet
that has a 4bolt downpipe flange.
be very similar to a normal t4 in its size so will act pretty much the same, will be cheaper than a t4 mind.
if your feeling quite flush with money then the smallest EFR turbo that you can run a t3 flange on is the 7064, they will cost £1200 delivered to your door.........but then your running a turbo that will outspool a t4, the 'on/off' throttle will be dramatically better and out flow it aswell by a good 30-40bhp, that does come with the benefit of its own boost controller and dump valve so potentially its not as bad as it seems.
if the turbo u suggest is similar to a t4 then it will be to big and to much lag. I only want about 450bhp and i was going for a t38 turbo. I wouldnt pay 1200quid for a turbo that hasn't been tried and tested as much. What was the turbo u mentioned that was 500pound?cheers luke
Matt Baxter
16-09-2015 08:30 PM
Cameron
14
09-08-2015 06:28 AM
