Rs2000 head on me galaxy 2.3
Old 11-05-2011 | 11:28 PM
cossyboy's Avatar
cossyboy
Thumbs up Rs2000 head on me galaxy 2.3
Wot needs to be done to fit a rs2000 head on me 2.3 galaxy And wot bhp am I looking on thanks
Old 12-05-2011 | 06:33 AM
Mark V8's Avatar
Mark V8
If the engine is in a Galaxy just use the RS2000 cams, the thermostat housing water ways are in different places on the RS2000 and you will end up with a very high compression ratio.
Mark
Old 12-05-2011 | 09:21 AM
Marcyg's Avatar
Marcyg
The Scorpio 2.0 head flows better than the RS one The water ways are different though. Just stick the 2.0 Scorpio cams, or RS 2000, they're EXACTLY the same and you should get a better drive. The 2.3 cams are nasty things.
@Mark V8; changing the head won't make any difference to the compression ratio. The compression is changed through the pistons on the twinkys. The 2.3 pistons are low comp ones, but are shite and collapse if they get too hot.
Old 12-05-2011 | 04:24 PM
Icurus's Avatar
Icurus
The combustion chambers on the 2.0 are smaller then the 2.3, and both engines have flat top pistons............
Old 12-05-2011 | 05:24 PM
Marcyg's Avatar
Marcyg
Depends which engine you're looking at. The 2.0 Scorpio pistons are bowled, same style as the 2.3, but as you say, smaller. The Sierra pistons have 4 cut out in the piston tops, presumably because at some stage the Sierra engine was supposed to be 16V, but never was. Personally I have never had an RS engine apart, but they same the same compression ratio as the Sierra 8V, so I could guess the piston design is similar. To be honest, both piston types that were in the Scorpios are crap, which is why I have kept my Sierra bottom end and plonked a Scorpio head on it. RS2K compression, power but using the Scorp head means it's set up for RWD so gets round the water way problem. The VIS inlet manifold is a very good piece of engineering as well
Old 12-05-2011 | 06:44 PM
Icurus's Avatar
Icurus
Sounds like an interesting project you got going there Marcyg, any pics?
Old 12-05-2011 | 07:09 PM
Mark V8's Avatar
Mark V8
If you use a 2.0 head on a 2.3 bottom end you're squeezing more into the combustion chamber and will end up with a CR of over 11:1 as the 2.0 chambers are smaller.
Some get away with it and some don't ......
A 0.010inch (0.25mm) skim on a Galaxy 2.3 head will give a safe CR.
Mark
Old 12-05-2011 | 07:52 PM
Marcyg's Avatar
Marcyg
A standard sierra 8v compression ration is 11.4:1, or 11.2, can't remember, but either way, the comp ratio isn't a problem. The problem is the shit pistons in the 2.3. After I get my 2.0 16v Sierra running, the next project is a 2.3 turbo and there's not a hope in hell I'll be using the standard pistons, will be custom all the way.
The heads though are all the same between the 2.0 scorpio, the 2.3 and the RS2k. There are a few of us who have researched this to the death and that's how the 16v Sierra with the 8v bottom end and scorpio head came about. Honestly, the compression ratio is changed through the pistons and stroke and not the combustion chamber, hence why they're all interchangeable.
Old 12-05-2011 | 09:04 PM
Mark V8's Avatar
Mark V8
I really can not be bothered to argue about combustion chamber sizes, as long as you are happy that is the main thing
Mark
Old 12-05-2011 | 09:05 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Mark
LOL I have given up replying on any 2.3 related RS2K thread on this site also now
Old 23-11-2011 | 02:10 PM
martysport's Avatar
martysport
What bollocks
Heads are all different
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
ST-170
04-09-2015 11:02 AM
Quick Reply: Rs2000 head on me galaxy 2.3
