claybar
Old May 10, 2011 | 11:36 AM
fezzaboyy's Avatar
fezzaboyy
http://a8.sphotos.ak.fbcd
Default claybar
whats the best claybar to use and when is the best time of day or weather to use im thinking when car is wet am i wrong
Old May 10, 2011 | 11:42 AM
Moonstone Mo's Avatar
Moonstone Mo
i rate the CYC fine poly clay and the bilt hamber one.
never had an issue what time of day/climate i have used it in,but your right keep the panel wet when claying with a quick detailer,water can be used with the bilt hamber one
Old May 10, 2011 | 11:46 AM
gjh's Avatar
gjh
Crikey theres loads of clay stuff in this forum now, I'v only ever used autoglym as I bought it as a one off but I liked it so thats what I stuck with, so I can't really say for other products. The car needs to be wet (not rainwater though, a light soapy solutuion of detailing spray/lube which you can get when you buy a kit), I did mine when it was really sunny and warnm and buffing was a workout so the best weather I would say is dry but not to hot, like if your going to do it in the summer, do it once its cooled a little. Hope this helps you.
Old May 10, 2011 | 11:48 AM
juicy 666's Avatar
juicy 666
i have used the bilt hamber and meguires clay kits and they are both really good! i currently use dodojuice clay lube which is nice and slippy!
Old May 10, 2011 | 04:59 PM
fezzaboyy's Avatar
fezzaboyy
well tried autoglym claybar today and i am impressed felt a bit uncomfortable doing bonnet and roof but paint is super smooth even removed hammerite black paint from when i done my drums
Old May 10, 2011 | 05:53 PM
naturally aspirated's Avatar
naturally aspirated
Bilt hamber FTW.
Old May 10, 2011 | 05:57 PM
S1's Avatar
S1
I usually use the Meguiars claybar but bought an Autoglym one at a show as it was cheaper, I've used it for the first time today and I'm that unimpressed I bought a Meguiars from the local car shop. The Autoglym one seems too soft and doesnt glide as well as the Meg, it also leaves bits behind if you catch it on edges of panels, trim etc.
Old May 10, 2011 | 05:58 PM
RichieST's Avatar
RichieST
I've used the mequiars clay, thought it was alright, but not used any other brands to compare. As for lube, I use a very strong solution of cheap car shampoo and water to keep things super slippery!
Old May 10, 2011 | 06:34 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Is this claybar lark hard work? is it a case of just going over the panel until it feels smooth? how long does it roughly take
Old May 10, 2011 | 07:21 PM
opposite lock's Avatar
opposite lock
There are lots of clays on the market now but the megs kit is good. Bilthamber do 2 different clays hard and soft depending on the contaminants on the car which are very good. If the sun is beaming and its hot i would do a panel at a time , once done , dry and move to the next panel . As for how long it takes it all depends on how bad the surface is and of course how big the car is and how fussy you are . Its taken me an afternoon before on a bad example .
Its worth mentioning that claying can marr the paint by the nature of it, keep it lubed well at all times and even then i,ve seen marring which could need polishing out.If you drop it on the floor my advise would be to throw it away as little grains of dirt will mark your car eventually .
hth
Old May 10, 2011 | 08:55 PM
neil73's Avatar
neil73
Bilt hamber, it comes in a 200g bar for about a tenner and only needs water for lube
Fudgey
Concours d'élégance.
14
Jul 1, 2013 07:57 AM
GazzaG
Jul 11, 2012 10:13 PM
Neil Clark
11
Dec 14, 2010 12:57 PM
olic1
Aug 2, 2008 03:57 PM
