Anyone spray painters? ive a quick question
Old 07-05-2011, 03:22 PM
moonstone_cossie
moonstone_cossie's Avatar
Default Anyone spray painters? ive a quick question
Hi as the title says i have a small question, i am taking into spraying my sapphire cossie and ive got the high build primer on and its all flattened down lovely but i put the base on and i didnt laquer becasue i wasnt happy with the finish.
it looks like a zebra so to speak and ive went both ways over the pannel well its the bonnet and boot lid im doing. and it looks exremly orange peely. i know its to do with the set-up on my gun but what do i need to adjust? or am i missing something?
oh and its a Upol gun and its moonstone blue.
Any help will be soooooo greatly appricated thank you
Old 07-05-2011, 03:27 PM
xr_craig
xr_craig's Avatar
Need to have a larger spray fan by the sound of it.
As for orange peel in basecoat, if it's still wet then there may look to be a bit, otherwise it must be far too heavy.
Old 07-05-2011, 03:42 PM
moonstone_cossie
oh so i need to adjust the fan bigger? and yes it looks very heavy when on the panel so i take it thats whats causing my very heavy orange peel? do i adjust the amount of paint coming out? or move faster?
thanks for your reply
Old 07-05-2011, 03:53 PM
xr_craig
xr_craig's Avatar
yeah bigger fan. Either will work mate, it's a case of trial and error as you don't want it too dry either.
Old 07-05-2011, 03:55 PM
moonstone_cossie
oh okay mate thanks very much for the help i like the painting alot but its hard when ive no clue lol
thanks again
Old 07-05-2011, 03:57 PM
xr_craig
xr_craig's Avatar
No worries mate.
What ratio have you thinned the basecoat to? 2 to 1? If it's not laying well maybe try a touch more thinners
Old 07-05-2011, 03:58 PM
moonstone_cossie
the base coat is 1:1 it was what i was told to paint with but is that wrong?
Old 07-05-2011, 04:05 PM
xr_craig
xr_craig's Avatar
That will be very thin, which probably won't be helping as far as the striping issue goes. If the fan/material level doesn't help then maybe try thickening it up a little.
Old 07-05-2011, 04:09 PM
moonstone_cossie
ok thats great thanks for your help ill def give that a try once these are dry and rubbed down again
oh and one last thing sorry for annoying you, once these are dry do i need to rub down with 2000grit? or can i just scratch the finish with scotch brite and spray over it again?
thanks Craig is it?
Old 07-05-2011, 04:14 PM
xr_craig
xr_craig's Avatar
Yeah it is mate.
It's up to you, if they are orange peely it might be worth giving them a quick flat before you put more on. Otherwise scotch will be fine.
Old 07-05-2011, 04:21 PM
moonstone_cossie
okay i will do that thank you for your advice mate
much appricated
Old 07-05-2011, 06:24 PM
kxkid
kxkid's Avatar
dont know how youv gotten on mate, but solvent basecoat should be mixed 60:40 it should never go on too wet, and if your still getting the striped effect, try opening the fan and doing twice as many passes with the gun. painting is a really hard skill to master. hope you get on ok.
Old 07-05-2011, 06:45 PM
mr yella
mr yella's Avatar
mmmm basecoat i mix at 50 /50 if 2k solvent , with turbo basecoat its 50/40 to 10% hardener .
Basecoat should never be orange peely , sounds like the mixing ratio is wrong ......
Old 07-05-2011, 07:27 PM
little bram
little bram's Avatar
Dont want to seem funny mate but it sounds to me that you dont know what you are talking about. What XR CRAIG has put seem right to me
Old 07-05-2011, 08:09 PM
mr yella
mr yella's Avatar
Ah glad you put me right , as after 25 years of being a pro commercial painter , i now know where im going wrong ......
Old 07-05-2011, 08:56 PM
little bram
well am no pro mate and it dosnt sound like the op is but it dosnt sound like he is mixing it wrong really, it is abit thin if he is not in a booth but still ok. just sounds like the gun isnt set up right.
and i havent painted for awile and as i said am no pro but why do you put hardener in basecoat. is Turbo basecoat diffrent to nomal basecoat
Old 07-05-2011, 08:59 PM
mr yella
mr yella's Avatar
Turbo basecoat is mixed different to 2k , putting hardener into turbo , makes it sit flatter .
Trust me on this one , data sheets don't lie .......
Old 07-05-2011, 09:04 PM
andy130
andy130's Avatar
what colour are turbo paints mate?
Old 07-05-2011, 09:19 PM
DazF
Designer/Fabricator
DazF's Avatar
Talking
Here we go again.........................................:top :
Sits back and grabs beer and popcorn...
Old 08-05-2011, 04:50 AM
mr yella
mr yella's Avatar
Any colour you want mixed up , some times the colour is not available in a paint system so it needs to be mixed in another type of paint , but that happens across the board .
Daz ....shut up .....
Old 08-05-2011, 07:06 AM
LukeDaisley
LukeDaisley's Avatar
orange peel could also be from having too much air pressure and holding the gun too close, if the fan is too small.
(I hate painting, so many things to go wrong.)
Old 08-05-2011, 11:53 AM
xr_craig
xr_craig's Avatar
Definately don't put hardener in this basecoat. Turbo basecoat is completely different.
chowfornow
14
05-01-2019 09:01 PM
tankybaby66
06-02-2016 02:24 PM
Fudgey
21
30-09-2015 06:19 PM
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Anyone spray painters? ive a quick question
