turbo temps
Originally Posted by pgt
600-700 degree's C at a rough guess
if its that hot would it not melt the turbine housing???
yea, what temp you on about?
you mention "charged air" and i take that as air exiting the compressor but before the turbo.
and on a T34 at 30psi+ id guess thats well over 100degC
but exhaust gas temp (ie heat of exhaust gas when its going thru turbine side of turbo) will be 700-1000deg C
yeah, I read it as compressor outlet temperature... in that case expect around 170degC at 30psi (assumption of 70% compressor efficiency)
http://www.stealth316.com/2-turbotemp.htm
http://community.asiaosc.org/~zaliman/TurboSelector.htm
JK12
33
26-04-2021 12:09 PM
