what turbo do you guys advice me ?
My fiesta engine specs:
steel crankshaft 92mm stroke
forged wiseco pistons 82mm
1942cc
compressie 8:1
big valves en ported head
kent 35
DTAFAST PRO 8 management
Aquamist waterinjection
803 injectors
pace chargecooler
boost 22-25psi
Im ready to buy a new turbo, but im not really sure what specs to take.
Thanks for your advice
1942cc
compressie 8:1
kent 35
803 injectors
pace chargecooler
boost 22-25psi
Garret GT60R - i was gonna suggest the GT70R with 1.47 A/R but i thot that might be overkill
![](http://www.turbocalculator.com/turbos/gar_gt42.jpg)
thats only $1049 too!!!
PMSL, i reckon that puppy should be on boost no later than 10Krpm on his engine, ideal for a road car.
I have a very tidy, dyno run only T3 hydrid for 375 with cut back blades, 360 bearing, left handed shaft and a .63 housing.
That should make the CVH FLYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
DEYTUKURJERBS
I think a .55 housing T34 would be ideal without wanting to spend too much.
.48 housing is probably fine too, tho id prefer a .55, .63 isnt really worthwhile as its only on greens.
Could go for somthnig fancier like a GT series but it more bother, wheras a T34 will at least bolt up to a normal RST manifold and use a cossie downpipe.
Compression is a bit high for my liking, esp with 25psi, but its not my engine.
big_Rad
15-09-2017 09:36 AM
