Broadband problem driving me mad. *help*
nothing but trouble since getting it.
had bt engineers out twice, once today who fitted a new box on my wall, tested it, said everything perfect, now tonight same old story
error 680 no dial tone, asdl light flashing on the modem and wont connect, and when it does it isnt for long.
any ideas what the fook is up with it?? even though it says no dial tone,
the phones working fine and there is a tone
bt
the no dial tone error is thrown up by the computer as there is no adsl signal, not normal dial tone,
do you know what else has been done on the line other than the new box today?
how far away from the exchange do you live? (if you know)
possibly an exchange error, if the engineer was a bit quick when he connected it he could have left the old wiring intact. or the equipment itself is faulty,
have you gone direct to BT or thru ya ISP?
was the engineer today an ADSL trained engineer?
sorry for the questions but you may need a woosh test etc to find the fault and that can only be done by certain engineers
best bet is to keep bugging them until your happy
gotta be some sort of adsl fault if you still got the phone working..
i`ve had times when me adsl has cut out at time but has been fine recently..
get them to send out a trained adsl engineer is you best bet as chrissy boy said..!!!
could be a isp problem too,
If you have a BT Voyager router (especially the 205 one), get it replaced - with the first one they sent us, you could fry eggs on it (it got too hot to touch sometimes). Apparently it was a design fault...!? Replaced it and the new one seems to be much more stable. That said, you should avoid running it with the USB cable (you never, *ever* need to plug the USB cable in - if you use the LAN cable you don't even need the BT install cd at all).
More info about the Voyager here: http://corz.org/comms/hardware/route...ter.how-to.php
/al
/al
yeah i see what you mean with that
no i was working , me dad was round, just said the engineer did a full test with a pc and everything perfect, thats the trouble, yesterday stayed on line for 7 hours running, tonight wont stay on for 10 minutes
couple of miles i think mate
they were out last week, said it was all ok, i think the new box today was just a case of maybe itll be better
its through bt yahoo, which is a pain in the arse as bt reckon its nothin to do with them and give you a number to ring and its always 25 mins minimum before they answer
not sure mate, he hooked up a computer and stuff
woosh test, ok mate, ill mention that to them.
yeah its just a pain in the arse, half hour just to get through to them
THANKS FOR THE HELP CHAPS
/al
/al
dont know what that is mate but ill check it out.
first time ive been able to get on since i posted this
have a good listen on the line without the asdl on.. any crackels on the line could aslo cause problems...
dial 17070... opt 2 quiet line test... keeps the line open to check for noise.. listen for a few minuites and see how you get on..!!! hth...
Originally Posted by bob1972
if ya want a WOOSH test done give me a call !!!or pm!
seems to be running ok today though
or that u can still access the test without the 1470 bit?
we need a BT engineers room
Dont know if ur sorted yet but ive been experiencing the same problem and the same error message for the past couple of days, mine was caused by being sent shite ADSL filters that the plugs nearly fall out of! Went round and checked em, giving em a firm push in and bobs my mums brother (not that she knows that). Dont know if this helps but i spent ages trying to figure out the problem and had decided it could only be BT at fault but obviously not!
Stu @ M Developments
41
21-08-2015 06:47 AM
