ecu help
Old Apr 23, 2011 | 08:51 PM
whizzisat114's Avatar
whizzisat114
Default ecu help
Hi there can anyone tell me how to tell what cosworth ecu i have off the number's on it?
Thanks David
Old Apr 24, 2011 | 12:01 AM
COLEYST200's Avatar
COLEYST200
yes dave i can why have you not asked me about this befor
Old Apr 24, 2011 | 12:04 AM
COLEYST200's Avatar
COLEYST200
The ecu types
Level 1 ecu - WD45.01 IAW045
Used in the 3 door Sierra Cosworth.
The case has an integral mounting bracket, a yellow mixture adjustment screw and the driver transistors are screwed down.
Level 6 ecu - W45.06 IAW045
Used in the 2wd Sapphire Cosworth.
The case has an integral mounting bracket, a white mixture screw and the driver transistors are clipped down. Has roughly the same inputs as the level 1 but uses a few different ic types.
Level 8 ecu - WD48.08 IAW048/01
or WD48.08 IAW048/02
Used in the 4x4 Sapphire Cosworth.
It also has a white mixture screw but there isn't a case mounting bracket to differentiate it from the level 6. There are a lot more components inside due to the extra analogue inputs.
Red label ecu pre-cat model. Green label cat model.
P 8 ecu - IAW048/P8
Used in the Escort Cosworth (Big turbo version only)
Externally the ecu looks like a L8 but the mixture screw hole isn't drilled through the case because there isn't a pot inside. The circuit board has now started to use surface mount chips but the eprom is still mounted in a socket. There appear to be at least 2 different types of ecu used - some have a 14pin ic where the circle is on the picture and some don't.(Note - The standard ecu doesn't have a baby board fitted, unlike the picture).
Old Apr 24, 2011 | 05:55 AM
whizzisat114
Cheers Coley your a wealth of info
just gotta find out which onw i got now
Old Apr 24, 2011 | 06:10 AM
whizzisat114
Just checked and ive got a L6
Im running a 4x4 loom are these two compatable as the 4x4 runs lambda and knock sensor's ?
Old Apr 24, 2011 | 08:17 AM
COLEYST200's Avatar
COLEYST200
only the P8 ran the lambda
Old Apr 24, 2011 | 08:37 AM
James @ M Developments.'s Avatar
Not true, green top saffs were emission based and ran closed loop as standard
Old Apr 24, 2011 | 09:26 AM
COLEYST200's Avatar
COLEYST200
O right on which of the ECU,S was that on then James
Old Apr 24, 2011 | 11:43 AM
L8 mate
Old Apr 24, 2011 | 10:00 PM
whizzisat114
I was sure id read that the L8 ran closed loop on the 4x4 saff
cheers for the reply's guy's
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
