4x4 fuel pump relay, where is it?
Is it behind the glovebox area? There are 3 relays there, 2 pink and 1 green. If it is one of these, how would I know i.e are there any markings on it etc. I can't pull them out and check them one by one by starting the car as the car won't start anyway
cheers, James.
cheers, James.
Whassup
Yes its behind the glove box but you need to look further down towards the transmission tunnel and firewall. Remove the clother under the glove box and its there.
Btw, you should have 2 yellow relays there also, one is fuel pump and one is injectors.
/Andreas
/Andreas
kosienutter
31
22-08-2015 09:55 AM
