HELP Needed
Old Feb 7, 2005 | 09:22 AM
steve rs's Avatar
steve rs
Default HELP Needed
i changed my petrol tank on saturday all went fine i filled it back up so it
has about £15 worth of petrol in then i drove down the road and it cut out
and now it doesn't look like the fuel pump is running its not the relay does
anyone know what ive done?
Old Feb 7, 2005 | 09:37 AM
Spiky's Avatar
Spiky
brital wires????
inertiar (spelling) swtich????
Old Feb 7, 2005 | 10:06 AM
steve rs's Avatar
steve rs
i have checked the enertia switch it was down does the fuel pump earth
on the top of the tank? could it be that has come off or something?
Old Feb 7, 2005 | 10:11 AM
Spiky's Avatar
Spiky
the fuel pump has 2 wires off it, both accessable from underside./
though saying that it is for 2wd, are you 2wd?????
just check there is power to pump...check fuse/relay
Old Feb 7, 2005 | 10:19 AM
steve rs's Avatar
steve rs
it is for a 2 wheel drive i checked the relay it is fine which fuse is for the fuel pump?
there is a brown wire that goes from the fuel pump on to the top of the tank to
the sender i think if this wasn't connected would it stop the pump working?
Old Feb 7, 2005 | 10:24 AM
Spiky's Avatar
Spiky
thats probably for the inhetia switch
best bet then is to get under neath and check power to both cables
only take 5 min's
Old Feb 7, 2005 | 10:28 AM
steve rs's Avatar
steve rs
do i just get a multimeter and put it in the connectors?
Old Feb 7, 2005 | 10:29 AM
Spiky's Avatar
Spiky
yeah no power no fuel pump
just need to put ignition on and power she be there, if not try starting it?
might be easier with 2 people???
Old Feb 7, 2005 | 10:36 AM
steve rs's Avatar
steve rs
ok mate cheers for the help ill have a look tonight
Old Feb 7, 2005 | 10:37 AM
Spiky's Avatar
Spiky
any probs ring me 07971 785 155, if i'm able to help i will
Old Feb 7, 2005 | 10:49 AM
steve rs's Avatar
steve rs
nice one cheers mate
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
