possible head gasket?
well think the head gaskets fooked on the cossie, took it down the village the day(4mile) stopped outside the shop and as a was walkin in to the shop the mrs noticed water runnin out from below the front wheel, opened the bonnet and there was water pissin out from below the exhaust manifold witch looks like between the head and the block, there was mega pressure in the water system but the car neva overhet and still has a heater, drove it back home temp gauge did come up a little but neva over lost the heater or boiled up,
what do u guys think do u think the gaskets is the problem or has anyone had this problem?
thanks in advance,
thanks in advance,
you need to pressure test it and see exactly were its leaking from. worst case it may be a crack fingers crossed it isnt!
also is there any mayo in the oil cap or ant oil floating on the coolant thats left in the header tank ?
you can also sniff test it to see if there are any hydrocarbons in the coolant system. but if your seeing the water leak then chances are it isnt mixing but its actually just loosing coolant externaly, are you sure there isnt any coolant pipes in the area that are split as dont forgett coolant will run along to the lowest point before it drips.
yeah mate a no wot ur sayin, there is no mix of the oil in water or water in the oil, dont think the pressure tester is needed mate as a mean its proper sprayin out like a bit of a jet wash from wot looks like between the head and block on the exhaust side of the engine, the only water hose near it is the metal one that runs from front of the head to the heater, or the one off the turbo but cheaked these and thats not the problem, would the pressure in the cylinder have blown the gasket out from between the head and block?
Was meant to have had a multi layer on it and was actually a standard gasket,it was fooked lol,had head skimmed and pressure tested and all is ok with it, so hopefully it should be sorted.
yes if your running more power with a standard gasket "material type" then thats exactly what can happen. do the gasket get it pressure tested etc and maybe a skim but try to avoid it if possible. but let the engineers tell you if it needs it. and get a multilayer gasket fitted
as he said you cant tell untill the heads off, sometimes they pitt so need skimming for this reason. and id say probably burton power or somewere like that. although they may be expensive. apart from cambelt kit ul need oil filter new oil coolant and id consider doing the waterpump wile im at it.
Think it would depend how old the gasket is etc. Your gonna need a head gasket,belt and tensioner, cam cover gasket and half moon seals,inlet manifold gasket,and maybe exhaust gasket. Head bolts if not long studded. As said get it pressure tested and sniff tested before buying parts.
This happened to me a few years back on an old cossie i had, exactly as you describe, the gasket had just rotted away and started leaking between head and block just under the exhaust manifold, was told it was a common thing on cossies, i just checked the head and block with a straight edge and all was ok, so just fitted new gasket and bolts from mattlewis motorsport and all was spot on, so i think you'll be fine.
Unlikely to be the HG if spraying, look closely at the core plugs first esp the one nearest no 3 on exhaust side, a rusted through pin hole will cause this.
Even if a duff HG pressure test will rarely show this in this area, when mine went shortly after I got my car I was putting 1 litre in every 8 miles or so to get home, driven gently.
Previous fixer, a ford garage didn't skim the warped head, or bolt it down correctly, 3 bolts were finger tight.
its the original one mate, heads neva been off, its a 1989 g-reg saph, 205 block with 140k on the clock, runnin stage3, 3 owners from new a hav contacted the old owners and looked through the paper work and the head gasket is from the factory,
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
