correct tap sizes for jic - " an style fittings "
Old 27-03-2011 | 12:59 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default correct tap sizes for jic - " an style fittings "
as title ,
looking to tap pout and fit jic fittings to my block and some other parts on the engine
just wating to know what the correct size taps would be for standard jic sizes
an 6
an 8
an 10
an 12
an 14
are they simpy metric threads or unf ect
anyone shed some light for me
Old 27-03-2011 | 01:02 AM
vaughant's Avatar
vaughant
Originally Posted by -beefy-
as title ,
an 6
an 8
an 10
an 12
an 14
I'm sure I looked at these on t'internet and they were metric,do you have a link though?I could tell you straight away then as some maybe metric fine etc.
Old 27-03-2011 | 01:38 AM
jon@work's Avatar
jon@work
-6 is 9/16 x 18 unf
-8 is 3/4 x 16 unf
-10 is 7/8 x 14 unf
-12 is 1.1/16 x 12 unf
-14 is not a typically used size
-16 is 1.5/16 x 12 unf
Old 27-03-2011 | 01:52 AM
-beefy-'s Avatar
-beefy-
cheers jon , are they 100 % unf , or do they have a metric equivilant
Old 27-03-2011 | 02:38 AM
jon@work's Avatar
jon@work
they are indeed 100% unf
Old 27-03-2011 | 07:30 AM
NEIL A's Avatar
NEIL A
Surely this would depend on the fittings used, I know on all the hydraulic stuff at work that uses jic fittings its normaly either npt-jic or bsp-jic fittings when going from a block to a hose.
It would also depend if you are using stepped fittings eg 3/8npt to jic12 or a straight size fitting would be a 3/4npt to jic12.
Old 27-03-2011 | 09:36 AM
markk's Avatar
markk
Originally Posted by jon@work
-6 is 9/16 x 18 unf
-8 is 3/4 x 16 unf
-10 is 7/8 x 14 unf
Old 27-03-2011 | 10:19 AM
carcollector's Avatar
carcollector
as said above i always got weld on adapters or NPT / bsp fittings to connect the quip stuff up.
Old 27-03-2011 | 12:09 PM
-beefy-'s Avatar
-beefy-
your correct neil it prob would , i just wanted to know if they were metric based or unf ect ,
saying that i looked on torques website and they sell a metric to jic adapters anyway , iirc m16 to -8 jic ,
thanks for the info guys
beef
Old 27-03-2011 | 12:10 PM
-beefy-'s Avatar
-beefy-
i plan to bud where needed , but in some places the parts can be tapped
Old 27-03-2011 | 08:06 PM
Try www.bgcmotorsport.co.uk
The owner Brian knows his stuff, it's all he does, a little goldmine he is on fittings, ace prices and no pressure sell, he actually talked me out of spending another Ł20 odd with him, suggesting a different way of doing my latest bit.
Old 27-03-2011 | 08:10 PM
JamesH's Avatar
JamesH
Good info on this thread
M K
12-08-2015 07:57 PM
Perfmr2
06-08-2015 08:30 AM
Graceland
31-07-2015 11:34 AM
