can you areoquip a cossie power steering setup
#42
I thought it was pretty obvious what I did seeing as I took photos of what I made ?
I made adaptors to fit into the rack to allow the fitment of -JIC/AN fittings.
After that you can use whatever hoses or pipes you want as long as they are suitable.
#44
Obviously if you welded threaded ends onto it or adapted it in another fashion, yes you could use any style of hosing that mates to those ends, be it stainless or otherwise.
But a long length of any flexible hose will have negligible cooling effect compared to a similar length of solid metal pipe. Preferably aluminium if it is for heat dispersal purposes
#46
That depends if you have an issue with the fluid overheating or not
You could add a proper cooler, larger reservoir, reservoir with a cooling loop inside, an external cooling loop.
You can do whatever you want no matter what way you do it
#47
instead of drilling and taping like the grp a racks could you not weld on suitable steel aeroquip fittings? welding in short burst to keep heat down,
What size would be suitable for the fittings? -6 seems about right to me
can you take the rack apart or is it pressed together etc
Thanks
Marc
Thanks
Marc
#48
Thanks
Marc
Thanks
Marc
hi marc i made adapters that on one end were the original fittings ie o rings etc and on the other - 6 male all one piece just replace with the pipes and screw your goodridge fittings on the end made of stainless
look at the pic i put up
thanks mark
#49
Same as mine. Best thing about it, it means the fitting can swivel, so easier to fit hoses without putting any strain on anything, and virtually no chance of anything working loose.
#56
i also need to quip the supply fitting from the electric power steering pump,
Here is the original fitting with a similar style o'ring fitting as the cossie rack except this one is compressed as the nut is tightened,
Mark - could you make this up with the original fitting thread as shown in the pic on one end and -6 on the other end? you would not even have to make the o'ring fitting as part of the threaded fitting for this as i can just cut the original down and insert it in the end seperate,
If i can find the thread size of the original there may even be an adapter out there already,
#57
Just checked and the saxo pump fitting is m16x1.5 so all i need is an -6 to m16x1.5 steel adapter for Ł2.88 from think automotive and insert the standard cut down o'ring fitting piece in the end as shown in the picture above and thats that part sorted
Unfortunately the return will have to be a jubilee clip as its just a plastic tube that is moulded as part of the electric pump resevoir and takes a standard push on hose so cant quip that
#60
http://www.cejn.com/Products/High-pr...ssories/Seals/
the maximum pressure for their dowty seals is 100 MPa, or 1000 bar
#62
Well i got my adapter today from THINKAUTO for my electric power steering pump from m16x1.5 to -6 and it already comes with the pump o'ring seal part of the standard fitting
Get them here for Ł9.94 plus vat and del
http://www.thinkauto.com/acatalog/On...tric__157.html
#65
Firstly, welding steel fittings to an aluminium rack might prove tricky.
And even if you could weld it, why make it so complicated and difficult by actually doing so ?
When a simple fitting can be made up that just slots into place.
#66
didnt realise the rack was aluminium, But surely aluminium fittings could be used instead and i only thought of it because the rack is new and on the bench as the car isn't built yet and i have a friend who is a fully coded welder so would be a piece of cake for him to do
Any other reason why not to you can think of?
#67
thanks mark
#70
made my fittings at home on the lathe and am happy how they have turned out
What i want to know now is regarding hoses!
Mark - you said you have used normal braided Aeroquip hose and alloy fittings and had no problems but when you read up on it online especially via Earls website is says you should only use steel fittings and special hose due to the 1000psi+ pressure you see in a pas system
Obviously power steering fluid is highly flammable and could be disaster if it burst,
Does anyone else apart from earls sell suitable hose?
Thanks
Marc
Thanks
Marc
#71
Whilst I use Earls myself, they are probably being 100% safe in their approach.
I think mine is about the only car Ive ever seen that has used such hose for PAS lol Every other car that has made their own pipes just use regular Stainless braided hose.
Although wouldnt really have matter. I wasnt using stainless hose no matter what
#73
I'd say their hydraulic hose would be more than adequate. Probably stronger than most stainless stuff.
I'd say it would look better. But then I just hate that stainless stuff lol
Overall though, for all you need even the Earls stuff isnt expensive.
You'd only need one 90deg steel -6 fitting and a straight -6 and slap a banjo onto the pump to connect to. And then a short section of hose.
The Earls stuff is handy purely because you just make it yourself.
There is obviously no requirement for pressure rating or steel fittings on the low pressure side. Just hose that is suitable for PAS fluid. Although most petrol style hoses will be fine.
#74
Well I ended up ordering the proper Eaton Aeroquip high pressure hose rated to 2250psi along with 15ft of hose,
Least I can be safe in the knowledge that the whole lot is done in the proper hose with proper steel fittings
I ordered enough to do all fittings even the low
Pressure side, plus I have steel through bulkhead adapters as my electric pump is in passenger footwell so bought 7 90degree fittings in the end and 15ft hose to be sure Im not short.
truffleshuffle
10-09-2015 09:35 PM
CrOwSoN15
10-09-2015 07:33 PM
Thanasis
07-09-2015 07:33 PM
