can you areoquip a cossie power steering setup
as title folks , i know they have the two steel tubes from the rack and then hoses to the pump and pump to resivor ,
has anyone converted the full lot to braided hoses and areoquip "an " style fittings ? - sizes ect
are the steel pipe sections nessacary ?
note, this is on the premise of a alloy pas tank
beef
beef
Just make up a fitting for the rack and weld a -6 fitting or two onto it
The bit that goes into the rack is just a stepped tube with an 0-ring. High pressure and low pressure are different sizes though.
Pump is straightforward, just a metric banjo fitting or whatever you want to use.
Only the high pressure pump-rack needs to be of suitably rated high pressure hose.
Earls do a specific range of hose for this, and heavy duty steel fittings.
Although I'm sure people do use the normal Aeroquip style braided stuff. I wouldnt have any of that near my car. I hate braided hose, it really looks crap !
competant bodger
i see where your coming from beefy but i would seriously look into the pressures involved i once tried repairing a hard metal ps pipe and failed miserably no matter what material i used allthough i didnt try braided aeroquip, you would have thought with it being aircraft grade someting would be available
Yes you can mate, the world cars ran quipped power steering and that's with a zf pump which is about 30 bar higher pressure than the standard cossie
Pump which is 90 bar I'm sure,
Mine will be getting quipped but not on the return as I'm using saxo electric pump and the return is a push on hose admit has no pressure behind it and is plastic so I cant quip it
hi beefy do you mean like this,i just make up a stainless fiitting that is the same on one end as the original pipes ie o ring etc then on the other -6 male ,this one was on my mk6 cossy fiesta van ,but have done it on both my cossy transits and my pickup before i went electric on pickup ,fiests i used carbon kevlar hose ,all the others braided with no probs at all ,i also put - 6 and -8 fittings on the pump and -6 on tank ,hope this helps
thanks mark
As much as I like that hose over stainless braided stuff.
Is it actually safe for PAS ? The Earls PAS hose is very heavy duty and rated at 2250psi operating pressure and must be used with specific heavy duty steel fittings. I imagine burst pressure must be some 2-3x that.
Their ProLite ( like the hose you have pictured ) burst pressure is 1400psi, and rated operating pressure of only 350psi.
And dont forget, PAS fluid is extremely flammable
mark
i have done 4 pas braided hose convertion and they are easy and i also added small oil coolers aswell and one of i put the tank under the wheel arch under the head light to keep the arches clear and they all worked very well. The easyest way is to cut the steel hose back but not to far so you lose the rubber pipe and braze on weld on dash 6 fitting and so on it dont take long
thanks mark
exactly like that mark mate !!!
should of knew you of all people would of done it lol
expect a txt lol
It's easy. Just make a small adaptor, weld a -6 fitting onto it and make your hoses whatever way you want.
Inlet and outlet adaptors are different sizes where they enter the rack. Although on the low pressure return side I welded a 90deg fitting on for clearance purposes.
hi steve my way is the easiest ,i just push a button on a cnc machine and go have a cup of tea come back done lol
mark
Glad this topic has come up as i have been asking the same questions obviously in the wrong places.
Looking at these only two hoses have been converted and two left. Can you only do the low pressure side ?
I have a Mk1 Focus RS and the pipes that go across the front have corroded so i am wanting to change mine. Its the two lighter coloured ones i was going to tap the hole for fitting. Can anyone advise would be greatly appreciated.
Unless the entire rack was stripped, I wouldnt be risking tapping it. It wouldnt take much dirt to damage either pump or rack.
if it's just the low pressure pipes that have corroded, and the bits photographed look fine. You can simply join that with suitable rubber oil/fuel hose and hose clamps.
Testing the future
don't forget that the long steel loop is for cooling the fluid. if you use hose instead, it will not get cooled so you should probably fit a cooler somewhere in the circuit.
So are my two light pipes the low pressure side ? they both go over the gearbox and across the front. Fitting a cooler will be no problem. i just need to get rid off the solid rotten pipes and replace with something more user friendly as with huge front mount these rotten pipes would need a slight bend. If they are the low pressure side could i cut the metal pipes on the straight push the braided hose over a good few inches and use a few clips ?
One of the pipes goes to the pump so if the pressure is generated in the pump i would assume one is the high side and the tank return low side.
Do not even consider putting a cooler on the high pressure side. That's suicidal.
Try and cool it before it gets to the rack which is difficult.
or cool the fluid in the reservoir so it isnt hot in the first place
please can anyone help with my problem,i have a series2 turbo with a airtec rad and recently bought the new pro alloy gen2 intercooler kit.since this has been on my car the cooling temp just rises into the red and boils over.i have checked all the usuall things such as fans going round the right way,coolant flow,thermostat working and even put the old pace back on car and temp was fine.i have just joined this site and not sure what to do or where to go on the pages so any help would be appreciated.
Without seeing though, hard to tell. Simple question, can air actually get to the water radiator ok ?
And when does it overheat ? idle, driving, fast ?
Testing the future
I can see what you're saying. But it will likely be hottest after it has done all its work ?
ie, immediately after the rack. That is where all the compression takes place, inside the rack.
Most of the time, say straight ahead position, virtually no pressure is created so the fluid is simply flowing in and out so cooler placement there probably makes little odds.
I Drilled & Tapped the Rack to use a screw in Aeroquip fitting , you could still buy the pinion seals from Ford when i did it so removed all the gubbins and shoved paper inside to prevent any swarf getting in .
