s2 boost issues
Old Feb 24, 2011 | 06:04 PM
matiow777's Avatar
matiow777
Default s2 boost issues
hi all ,my sister bought a mfi rs turbo cabriolet that is a non runner, just recently managed to get it running it had a breather pipe missing that goes from rocker cover to fuel metering unit.
the car runs very sweet but the turbo dosent seem to be doing anything, it has a boost gauge and when you drive the car it only goes to "0". and carnt ever seem to hear the turbo,
All the boost hoses are mint and on tight, it hasnt got a dump valve fitted. however it has been fitted with adjustable boost valve, tried turning this in and out and makes no difference, took the hose of the turbo and checked that the compressor wheel is free to rotate and dosent have any free play.
i dont know where to from there so any pionters would be mint. thanks
Old Feb 24, 2011 | 06:21 PM
herbcosworth's Avatar
herbcosworth
herbcosworth
does the actuator have any resistance on it and is the waste gate shut?
Old Feb 24, 2011 | 06:26 PM
Chopshop85's Avatar
Chopshop85
I would go with issues with the actuator. Sounds like it's not holding any pressure.
Old Feb 24, 2011 | 06:31 PM
escoskmv's Avatar
escoskmv
make sure the actuator arm hasent fallen off the waistgate and if poss get some air pressure to it an check wot pressure its opening at
Old Feb 24, 2011 | 07:41 PM
matiow777's Avatar
matiow777
hi mate thanks for your reply, could you please tell me how to check both the resistance on actuator and the wastegate cheers.
Old Feb 24, 2011 | 07:59 PM
herbcosworth
herbcosworth
you can feel the resistance by trying to pull the actuator arm away from the diaphram end, to check waste gate is shut i would dissconnect actuator arm to see if the wastegate is moving, then reconnect the arms you should have to pull actuator arm a bit to slide it over wastegate arm, hope this helps mate, confuse myself sometimes trying to write it lol,
Old Feb 24, 2011 | 09:04 PM
matiow777's Avatar
matiow777
ok will try all these things 2mow and will get back to you thanks again.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
