weird brake light problem
Old Feb 24, 2011 | 06:32 PM
escortzetecturbo's Avatar
escortzetecturbo
Default weird brake light problem
When I put my foot on the breaks my head lights come on and only the rear left break light comes on, even does this with the ignition off, on a mk4 escort any ideas?
Old Feb 24, 2011 | 06:34 PM
herbcosworth's Avatar
herbcosworth
herbcosworth
single filament bulb in brake bulb holder where a twin filament should be possibly?
Old Feb 24, 2011 | 06:37 PM
Cozziekid's Avatar
Cozziekid
Bad earth problem
Old Feb 24, 2011 | 06:39 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
as said. single filament. i did it years ago on an orion
Old Feb 24, 2011 | 06:40 PM
escortzetecturbo
Nah just brought 2 new double fillament bulbs, I have checked and cleaned all the earths I could find but no difference
Old Feb 24, 2011 | 06:44 PM
vaughant's Avatar
vaughant
Bad earth,mk4 disco lights!!!try all the shitty connector pieces as well,they corrode like fuck.
May help to trace it via disconnecting one side of the rear lights then see if the problem comes back,this should help in which circuit maybe causing the issue.
Old Feb 24, 2011 | 06:58 PM
herbcosworth
herbcosworth
faulty lamp? put new earth on to metal on the bulb holder see if it stops it.
Old Feb 24, 2011 | 07:07 PM
rich123's Avatar
rich123
bad earth mate
Old Feb 24, 2011 | 07:10 PM
escortzetecturbo
Just went out and took the connecter off the right hand side one that wasn't working, sprayed it with wd 40 and used some sandpaper on the end of a screwdriver cleaned all the little metal contacts put it back together, works fine now thanks :d
Old Feb 24, 2011 | 09:50 PM
vaughant's Avatar
vaughant
No probs mate,it's really common on them.if it keeps happening,you can get some spray electrical grease that should do the trick.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
