st200 low down ticking
hi my st200 has started to tick under low load and is starting to lose power iv done a compression test and the front bank are coming up at just under 8 bar which i think is bad.
does any one have any info that might help me also if worst case where i can get a headgasket set for a good price
cheers for any help
cheers for any help
the ticking can point to knackered headgasket, but also, they eat exhaust manifold gaskets, and they tick when they go aswel. as for the lack of power, is your IMRC working ?
i replaced the imrc so it picks up in later revs just low down struggles a bit. i have just bought stainless steel manifolds which come with new gaskets so will be doin them soon just debating weather to do the head gaskets at same time
i wouldnt bother replacing them if there not gone, the rear bank HG is a fu*king nightmare to do.
what do u think to the low compression test in the front bank hardly even hit 8 bar arrcording to haynes manual should be 9-15 bar
Low comp can be gasket ,rings and valves but for the front bank to go low you may have a timing problem thare was a thread I read the other day like this ,basics is the timing chain slipped a tooth and the valves cotacted the pistons and bent thus poor comp reading hope this is not it but start your checks now if its an exhaust gasket you may well be able to feel the escape of gas with your hand or mist the area with a spray and look for gas movement.
would you keep me updated as Im puting a st200 engine in my coog.
Lucifer II - 666
I know of a low milage engine available, PM if interested.
My 200 estate was "ticking" The down pipes to exhaust flanges were lose.
Check the exhaust system before you go saying head gasket...........
Might be something small, you never know
Gary Krishna
I've got a V6 Ghia X as my runabout and it developed the tick about a month after buying it and also has an oil leak which is coming from between the rear head and block. It's been like this for a few months now.
Yesterday while I was doing my checks under the bonnet, I noticed the coolant was low so went to go and top it up. I hadn't used it for a day or so but took the cap off and the amount of pressure in there was unreal!
Had a sniff and smelt of exhaust fumes! Deep joy!
The car only cost me £400 so I really can't be fucked to pull it apart and do the head gaskets on it and I don't really have the time to either! Just shoved a load of K seal in there and will just keep an eye on it!
It's a shame really as I do like the car and I've serviced it for the past 10 years as it belonged to one of my mates who I bought it from.
iv got some stainless steel manifolds to do so shall do them 1st and see whats shes saying then, some one else also mentioned the egr valve pipe was leaking so could be that
