MP3/Music File question- playing- kb per sec
Old 02-02-2005, 02:29 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Default MP3/Music File question- playing- kb per sec
Im presuming technicly the higher the kb/sec it plays at, the better quality?
Is there really a noticable difference in music quality or whatever between a file thats say 90kb/sec and one thats 130kb/sec? Cause i cant tell the difference, but my speakers are wank
If you feel there is, what you feel is a good enough quality?
Ta
Old 02-02-2005, 02:32 PM
CraigN
CraigN's Avatar
yes defo is
i record all mine into 192kb
as i use my ipod in my car 192 i find very good quality
Old 02-02-2005, 02:46 PM
Jim Galbally
Jim Galbally's Avatar
130 kb/sec = 130 kilobits per second, so each second of audio takes up 130kilobits of information (divide by 8 to get kilobytes)
if you know the bitrate and the length of the sond, you can work out the size of the file
unless its encoded with VBR (variable bitrate) where it varies the bitrate depending on how much it needs... unfortunately VBR fiiles are notorious for fucking up
Old 02-02-2005, 02:58 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
fair enough, whats that gotta do with owt jim?
it just got me thinking as i downloaded the same track twice, one the smaller file thats 96kb/sec and the other a bit bigger and plays at 128kb/sec and im fucked if i can tell the difference
Old 02-02-2005, 03:00 PM
Spiky
Spiky's Avatar
presonally i cant tell the diff between 128 and 192,
i normally would get/rip anything low than 128
Old 02-02-2005, 03:03 PM
Jim Galbally
steve, you wont be able to tell the difference really unless you have v. good hearing. if you compare one ripped at 192 and one rippes at like 64 you can easily tell tho... sounds like the difference between listening to a CD and listening to the radio
Old 02-02-2005, 03:05 PM
SteveT
SteveT's Avatar
If I'm ripping my own CD's to MP3 then I use 192 Kb/s or 160 kb/s. Hard to tell apart.
But I can notice the difference between 128 and 192. Saying that, 128Kb/s is still ok for your average stereo, and will sound ok.
But bit rate is not the whole story, for example, if you find two versions of the same song on Kazza or whatever, and one is 128kb/s and the other is 192 kb/s , you can't assume that the 192 one will sound better. You don't know which algorithm which was used to compress them, or which quality setting/compression speed was used, or what quality the original source of the music was
Also WMA is supposed to be better than MP3 at the same bit rate.
steve
Old 02-02-2005, 03:14 PM
Phil
Jeebus
Phil's Avatar
I always use 192, as you can definitely tell the difference at 128 - high end looses a lot of information
Old 02-02-2005, 03:21 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Phil- What do you mean by high end? high frequency notes? ie Trebble?
Well that dont bother me in the slightest really so thas ok.
Old 02-02-2005, 03:23 PM
Adrian
Adrian's Avatar
I have about 60gb all encoded VBR and have had no issues what so ever either as audio CD's or MP3 CD's.
Guess you just unlucky Jimbo.
Old 02-02-2005, 03:27 PM
Jamz
Jamz's Avatar
What a load of bollocks
Old 02-02-2005, 04:18 PM
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
I find using MP3 encoding 128kbps is good enough for me - even when using a high quality amp and speakers. Im not sure about wmv. formats as i don't use them much, but i've heard there better, ie: can encode sound in 56kbps format and still have cd quality - could be bullshit
Old 02-02-2005, 04:24 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Anyone?
Old 02-02-2005, 04:54 PM
Phil
Jeebus
Phil's Avatar
Yes Steve on the treble. You would think it doesn't bother you being a bass monkey but the cymbals etc are still there, just they sound crap! (Wavy instead of sharp is the best description I can think of )
Everyone hears differently though I guess so it could just be me, but i'v never had a problem doing everything in 192, 160 is usually perfectly adequate but where size isnt an issue I do 192.
Also if you use Windows Media Player to do it you need to choose mp3 in the settings instead of wmf or whatever it is that it uses.
01-11-2015 06:53 PM
pabloXR
21-09-2015 12:42 PM
Bailes1992
03-09-2015 02:17 PM
COSWORLD
14-08-2015 07:40 AM
Quick Reply: MP3/Music File question- playing- kb per sec
