transit connect problem
Old Jan 30, 2011 | 06:20 PM
cossiegreg1's Avatar
cossiegreg1
Default transit connect problem
18tdci 90ps 97k.
The last couple of days, its been harder to start on a morning.
just been turning, then it pulls diesel through and runs like a dream (hardly no smoke)
but its now getting worse.I was on 20 min this morning cracking injectors off trying to bleed it.
once i got it going it was running ok considering.
When driving and i take it all the way to the rev limit, the van feels like its surging/holding back.
Also if i switch it off (for 1 min)then go to fire it up, it still turns over quite a bit before it fires.
and the glow plug light came on today on m/way and the van wouldnt go above 50mph
a quick on/off with ignition got rid of it.
there is no visible signs of a leak in the diesel pipes. anything else should i be looking at before i start changing injectors and pumps.
Cheers.
Old Jan 30, 2011 | 06:25 PM
phil robson's Avatar
phil robson
could be worth changing fuel filter and chuck some forte diesel treatment in for what it costs then see what happens, sometimes need a tow to get going these after fuel filter change mind, also check glow plugs
Old Jan 30, 2011 | 06:27 PM
bigjohn0's Avatar
bigjohn0
If i was you mate i would start with a new filter and glow plugs. There is a drop back valve you can buy from good motor factors and you just fit it in the fuel line to stop the diesel from going back to the tank and causing starting problems.
Old Jan 30, 2011 | 06:29 PM
dojj's Avatar
dojj
Resident Wrestling Legend
on ours most have been the glow plugs when the glow plug light starting coming on and causing issues
Old Jan 30, 2011 | 06:37 PM
cossiegreg1
ill test glow plugs in morn and fit fuel filter, i reckon its something more though
the van had been driving for 2 hours then it still struggled to start
Old Jan 30, 2011 | 06:41 PM
mercury grey minter's Avatar
mercury grey minter
Fill the filter with diesel before fitting,really will be a bugger to start if you don,t .
Old Jan 31, 2011 | 05:58 PM
cossiegreg1
diagnostics is saying diesel pump.
where's best place to get one?
Old Jan 31, 2011 | 08:18 PM
dojj's Avatar
dojj
down at the car auction, along with a new van if it's going to cost millions
Old Jan 31, 2011 | 08:40 PM
jamie's's Avatar
jamie's
they're coded to immolbiliser on them
think they're between Ł500-600
2nd hand 1's can be fitted but they need to be reprogrammed, so remember to budget for that
but a new/recon pump is just fit and go
Old Jan 31, 2011 | 08:56 PM
petenete's Avatar
petenete
i had one like that a couple of weeks ago it ended up being the throttle pedal Ł85 quid from fords
Old Feb 1, 2011 | 06:12 PM
cossiegreg1
You were the one who was saying there bullett proof.
Load of scrap if you ask me.
Old Feb 1, 2011 | 07:30 PM
dojj's Avatar
dojj
when they are running fine they are great, most of our vans are running with an excess of 100,000 miles now and they are all 58/09 plate vans
it's just silly things that don't get done under warranty and basicly wear out that cause issues later on in life, but if you look after them they will last forever
Old Feb 1, 2011 | 11:06 PM
capricougar's Avatar
capricougar
check fuel filter,if its got a "GLITTER" in it the fuel pump is disintergrating! first check pressure on fuel rail, fuel pressure regulator could be duff,this would showup as fuel pump fault on diognostics.as they dont show mechanical faults,only electrical! a also known fault is the crank senser. fuel pumps are known to give up but normally at around 120k...
Old Feb 2, 2011 | 04:26 AM
We have had a few vans at work that have been holding back when driving them and we have put fuel filters on them. If you change the filter you have to bleed it through or you will be on forever getting it to start.
Old Feb 2, 2011 | 07:13 AM
clyde 1800's Avatar
clyde 1800
same thing happened my big brothers renault trafic
it was 2 years old and chipped
i will find out what he done to fix it if you want
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
biggiejody
Sep 19, 2015 10:25 AM
Flatlinedan
Sep 18, 2015 12:41 PM
