Can an engine get "adicted" to easy start?
Turbocharging Technician
My opinion is that there has to be a major problem with the engine or the management/fuel/ig side of things in the first place in order for you to be using easy start. By using the easy start you are ignoring the main problem with the engine and it will only get worse. Although its not the first time ive heard people say "its addicted to easy start" but surley if you never fixed the problem in the first place it will only get worse any way? what is everyone elses view on this? am i missing something here
*** Sierra RS Custard ***
Using easy start wont make an engine harder to start when you are not using it, in fact sometimes it can make it easier to start as its quite a good cleaner of the inlet tract so in the case of carbs with sticking pistons due to gunk etc (ie a mini SU) it can actually help fix a problem.
If it doesnt start without it, its not addicted to anything, its simply not fuelling or sparking correctly.
Your view is correct, you are ignoring a problem which is getting worse, so thats why it gets harder to start without easystart.
Gary Krishna
I don't think it does them any favours at all if easy start is used all the time as it can cause the piston to rattle it's way down the bore as it is so volatile.
I only ever use it on diesels if it has a glow plug issue or low fuel pressure when cranking to get it started and tell the owner to go straight to the garage to have it sorted.
The amount of people that get pissed off with me because I won't sell or give them my can of easy start because they don't want to spend out getting the issue fixed is unreal!!
I totally agree as well, baffles me how a lump of metal can get addicted to anything.
That said in very cold climes it can be really good on some stubborn old diesels engines/designs, as comp heat is not enough.
as chip stated it act's as a good cleaner would it not wash the bores causing damage to the rings causeing lower compresion so there for the "need" of easy start every time to start
it's just that sounds like what i would call an adiction
Engines do get sort of addicted to easy start, we have a fork lift at work which wont work with out the stuff. its washed the bores that much causing a glaze and theres bugger all compression because of it. bear in mind the fork lift has been started with easy start for the past five years
st170 breaking
the driver gets addicted to staying away from a repair bill
yoou can stop giving the engine a 'hit' but then you'd have to fix it
in oz my camper ran mint until we went south where it was cold as fuck, wouldnt start for shit but an aussie dude on the camp came over with a can of deoderant and it starter on that (i do know why) soon as were were north again it was fine
was i fuck gonna go fix it so i bought some aerosol lube and started on that if i needed
used easy start on a old mercedes v10 diesel,wouldnt start without it when it was cold.
so yes they get addicted,had to use more and more easy start.
We used it on OLD worn up diesel engines, ford transits/tractors/trucks/ old cars when the pre heat was fucked or the engine had low compression
Made in Scotland
I think it's because Easy Start has a lower point of ignition, so it warms the air in the combustion chamber, therefore 'coaxing' the engine into life and allowing it to chug along under its own steam. That's usually on proper old skool diesel engines without glow plugs, although, I suppose if you have a heater plug relay go tits up on a more modern diesel engine then you'll be in a similar situation and it may help start the engine.
Pretty dangerous though, causing a big bang artificially isn't going to be good for the engine so it's best not to start banging the stuff in time after time... rather just fix the problem, no matter how addicted to the smell you are.
Cheers,
Grant
Cheers,
Grant
i actualy set our forklift on fire yesterday witheasy start
i sprayed it in then it caught on the heater plugs and shot a flame out the inlet mani
put the whole side of the engine up,
was quite funny, nearly got myself on fire with it
it realy is very very combustable lol
When we have a troublesome engine to start, we give it a snort of "coke" as we call it.
They become addicted to it due to the "cocaine" causing a big increase in combustion pressures damaging the piston rings of the first few ignition cycles. The starting fault is compounded by a drop in compression meaning it becomes reliant on a snort to get it going from cold. Diesels suffer as they are already mega high compression where as a petrol will cope more easily.
LOL, once easy start is used an engine wont start without it, OBVIOUSLY! it didnt start before, thats why you needed the easy start in the first place!
Same as old Army wagons. Having to use cold start all the time in winter months and on some wagons even in the summer!
weak spark, too rich or lean, low compression, wrong ig/inj timing, air in the diesel system, faulty heater plugs, wrong gaps/fouled plugs are all good reasons to use easy start. Easy start will not fix these problems though! they will not majicaly go away
you speaking about the tractor? they run very funky pumps, id immagine that this one needs a bit of tweaking, but they never idle well or start well for that matter as the pump cant regulate that low down any more lol
Yeah the tractor. I aint clued up on mechanics and that but thought that a new engine from cold as well as the turbo would need to be used gently till its warmed up rather than revving the tits off it.
http://www.youtube.com/watch?v=ry6Aom1VE7c have a look lol
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
